Old January 21, 2012, 12:05 AM
Default NEED Opinion :d
MOBO: ASUS P6X58-E PRO LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
CHIP: Intel Core i7-960 Bloomfield 3.2GHz LGA 1366 130W Quad-Core Desktop Processor BX80601960
PSU : CORSAIR ENTHUSIAST SERIOES V2 TX850 WATT
Graphics card: 2 SLI GTX 560
RAM: Kingston HyperX 12GB (3 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) XMP Desktop Memory Model KHX1600C9D3K3/12GX
FANS: 15 120mm fans
2 Scythe KM02-BK 5.25" Fan Controller
Old January 21, 2012, 12:17 AM
Babrbarossa's Avatar
Welcome to the forum! Are you asking if these are good components for a new build? the 1366 platform is on the way out, and you'd be better off going with an i5 2500K with an x79 mobo these days. The 850 watt corsair PSU would run this build.
To be sure, you can check on the PSU calculator link below.
http://www.google.ca/url?sa=t&rct=j&...-ntqb190Rj0S4g
I deleted your other thread because it was pretty much a duplicate of this one.
Old January 21, 2012, 08:17 AM
If you want us to help you, list what are you gonna do with the rig.
Since your buying new, i would not go for the 1366 platform. You would be better to buy cpu/mobo/ram used, as it is pretty easy to find on forums/ebay (the chips are alittle harder to find, they sell so fast!).
Or, if you're just gaming, go 1155. Cheaper and more FPS than the 1366. The 2500k is unbeatable at gaming!
Old January 21, 2012, 11:56 AM
go 1155 or 2011 if you have the money. the psu is a bit low but could be ok
Old January 21, 2012, 08:47 PM
yea i know i was just wondering if the psu would power that cuz i don't want it going up in smokes lmao
Your opinion on what I should buy TokeR Video Cards 12 April 3, 2011 05:43 AM
Want your opinion martin_metal_88 Troubleshooting 10 February 17, 2010 10:04 AM
what's your opinion? jay51 Cases 13 January 8, 2010 09:33 PM
Need Opinion on PSU Xerin New Builds 3 November 2, 2008 02:54 PM
Second opinion before I buy Slinger Overclocking, Tweaking and Benchmarking 26 January 3, 2008 09:05 PM
