Old January 15, 2012, 05:04 PM
Default Building gaming PC. (Specs)
Hi, I'm going to build a new gaming PC mostly for World of Warcraft. I'm not sure if all parts fit together and if there are other parts in the same price category which would work better. Thanks for all help.
CPU: Intel Core i5 2500K 3.30GHZ
RAM: Corsair Vengeance DDR3 1600MHZ 8GB CL9
GPU: MSI GeForce 560Ti 1GB PhysXh
HDD 1: Crucial m4 2,5 64GB SSD HDD 2: Seagate Barracuda 1TB 7200RPM
PSU: Chieftec Nitro Series BPS-650C 650W
Case: Corsair Carbide 400R Midi Tower (black)
Motherboard: Asus sabertooth b3 P67 (S-1155) ATX
CPU cooler: Corsair H60 Hydro Series
DVD-Writer: Lite-On DVD-RW Writer
Old January 15, 2012, 05:06 PM
aside the power supply looks good
Old January 15, 2012, 05:09 PM
What should I change it with?
Old January 15, 2012, 05:11 PM
corsair, antec, or a seasonic
Old January 15, 2012, 05:50 PM
Supergrover's Avatar
Dont forget to grab a 50mm fan for the Sabertooth, While not "needed" it does help keep down the board temps when OCing or in a smaller case.
R.I.P.
techman95's Avatar
a corsair tx 650, its "rated" for 650 watts but i can run 2 6870's off of it along with an overclocked 1090t so....there's that. *note i dont run crossfire any longer*
Amd....definitely a blond female.....not much on the cpu side, but always strutting about showing off her gpus
Building a Gaming PC jmann001 New Builds 17 October 4, 2011 02:38 AM
Is the ASUS K53TA laptop good for gaming? Specs within Zak_M Video Cards 1 September 1, 2011 02:13 PM
Building a Budget AMD Gaming Rig crunchbite New Builds 22 February 4, 2011 04:23 PM
Building a lew system for gaming LacrosseTown New Builds 4 May 9, 2010 09:33 AM
Need Help Building a Gaming Rig for $800 mr_syn New Builds 13 January 10, 2010 05:47 PM
