Old January 13, 2012, 11:49 AM
Poison Ivy's Avatar
Arrow Quick advice needed: $70 for wireless PCI-E card or just get USB?
I made a booboo my new mATX mobo only has one PCI slot, which I need for sound card. Should I get this PCI Express adapter .... D-link DWA-566 for $70 or save money on a USB adapter like this? Reason I ask is I have not had much luck with USB adapters in the past but maybe they are better now.
Also is there any difference in range in these Pico adapters from a regular USB adapter?
FTR I will be using this quite far from the router, outside.
Old January 13, 2012, 11:56 AM
Poison Ivy's Avatar
I just found a USB wifi adapter that I had laying around so I can use that for now, should I get a PCI-E card still?
Old January 13, 2012, 12:15 PM
Soullessone21's Avatar
I have had a lot of the Dlink ones fail in my store I would go with Asus or TP-Link for Wireless PCI cards
Old January 13, 2012, 12:17 PM
Soultribunal's Avatar
Or failing that working (The USB one) get a powerline adaptor perhaps?
-ST
www.realhardwarereviews.com
Old January 13, 2012, 12:49 PM
JD JD is offline
I would opt for a PCIe card with removable antennas. That way you can always get higher gain antennas if the signal strength isn't enough.
I probably wouldn't buy from Future Shop though since I imagine you're paying more than you need to.
Old January 13, 2012, 02:19 PM
MARSTG's Avatar
I would go USB, TP-Link is quite reliable, most (newer) D-Link hardware quits working after a year, be it USB adapters or routers.
Old January 13, 2012, 03:00 PM
Poison Ivy's Avatar
Hmm conflicting info.. so you think a USB is as good as an internal PCI-E? The Future shop one is out now obviously (the price was not too bad though close to online shops).. Powerline one won't work in my situation as we move around.
I think I will just use the USB for now that I found and buy a non-d-link PCI-E x1 card.
Old January 13, 2012, 03:03 PM
stoanee's Avatar
Linky to higher gain antennas please?
heatware
Old January 13, 2012, 05:00 PM
i wouldnt buy the usb model
i made that mistake
I bought the belkin micro adapter
There is a thin wall separating my router from the computer, and although the computer indicates a very good or excellent signal, it still connects only with 18, 24 or max of 48 Mbps
Old January 13, 2012, 07:46 PM
Poison Ivy's Avatar
Yea I figured as much, I will get a PCI-E card in my next order.
Need quick advice on wireless routers.... chrisk Networking 13 June 14, 2011 07:37 PM
Sound card advice needed Rhodan Audio 2 October 26, 2010 11:23 AM
Advice needed on a budget video card Synth Video Cards 15 September 4, 2010 05:29 PM
video card advice needed drako Video Cards 13 July 25, 2010 11:10 AM
Budget video card advice needed please. Mumbly Video Cards 9 January 17, 2008 05:59 AM
