Old January 13, 2012, 09:36 AM
Default Need help for my first time build..thanks
Hi everyone, ive been planning on building my own gaming rig. This will be my first build and i really need your help. As of the moment i store an Intel Core i5-2400 (3.1G). For my MB and GPU, im quite not sure so i didnt buy yet. I think for my MB = Asus P8H67-M LE H67 V/S/GL + GPU = PowerColor HD6870 1gb ddr5. I dont intend to xfire nor OC. Please please let me know if there is something wrong with my build or maybe other better options you can suggest. Thanks
Old January 13, 2012, 10:53 AM
Babrbarossa's Avatar
There's nothing wrong with that build- that a good mATX board.
That build isn't the best for overclocking so if that isn't your goal and you're on a tight budget, you might consider pairing that board with an i3 2120 and save some more money- it has the same clock speed.
Old January 13, 2012, 06:20 PM
MARSTG's Avatar
Only P67 and Z68 can overclock CPUs via multiplier, via FSB they fall very short at 106-108 MHz FSB. And the only overclockable cpus are the i5 2500k and i7 2600k/2700k. Otherwise nothing wrong with that build. But I have to agree that for gaming only the i3 would be the better choice, very good performance and cheaper.
Old January 13, 2012, 07:44 PM
So if thats the case. Correct me if im wrong, but do you think my upcoming Asus P8H67-M LE H67 V/S/GL bottlenecks my Intel Core i5-2400 (3.1G)?
Old January 13, 2012, 08:01 PM
MARSTG's Avatar
No it does not
Old January 13, 2012, 08:09 PM
thanks!
Old January 14, 2012, 12:11 AM
spend a bit more and get the 2500k. Well worth it =D
Old January 14, 2012, 07:45 AM
Thanks for the advise, i already bought though. Btw, is 650w psu good enough for my build?
Old January 14, 2012, 08:04 AM
MARSTG's Avatar
Oh yeah, no issues, but make sure is a 80 plus at least, you could also go 80 plus bronze. what have you got as cpu?
Old January 14, 2012, 12:09 PM
I got the core i5-2400 3.1ghz. Anything wrong with it?
First Time Build, Need Some Help! porkpork New Builds 13 November 5, 2011 11:34 AM
First time PC build Big Iron New Builds 9 December 19, 2010 05:08 PM
First time build soambiatch New Builds 7 August 25, 2010 05:56 PM
First Time Build pRefy New Builds 40 March 22, 2009 12:52 PM
First time build CGW Troubleshooting 10 September 12, 2007 07:27 PM
