Old December 29, 2011, 10:24 AM
Default Weird sound
So I finished my first computer build and I notice when I turn it on there is a weird sound coming from it. I also noticed it doesn't seem to be the fans. Any ideas.
Old December 29, 2011, 10:32 AM
supaflyx3's Avatar
What kind of weird sound? Like something rubbing, a beeping, or something else
Old December 29, 2011, 10:36 AM
great_big_abyss's Avatar
Without any description of the sound (buzzing, humming, grinding) or computer specs, I'm tempted to say that it's a nest of crickets in your power supply. A can of raid should solve that.
No but seriously, most of the noise in your PC comes from the moving parts in your case: your fans, HDD and optical drives. If it's not the fans (bad bearings, cable rubbing against fan blade?) then check to see if it's from your hard drive or DVD drive.
Another option could be a cheap or old powersupply humming.
Old December 29, 2011, 10:49 AM
sound from your hard drive ?
Old December 29, 2011, 10:51 AM
Specs
Motherboard-DX58SO2
Graphics card-gtx560 asus dcuII top (somthing like that)
Ram-corsair 12gb xms
CPU-i7 960
Power Supply-silver strider 1000-p
Hard drive-seagate barracuda 1tb
So I don't think it is the fans and the sound is not beeping,humming or grinding. It might just be a normal part of it because the computer seems to work fine.
Old December 29, 2011, 10:53 AM
Dont think it the hard drive it not near the sound I think it might be the motherboard.
Old December 29, 2011, 11:04 AM
SugarJ's Avatar
Is it a high-pitched squealing? Might be a coil on the GPU.
Old December 30, 2011, 12:39 AM
Dzzope's Avatar
This was my though..
Maybe try record or describe it may give us more of a clue to the cause.
Old December 30, 2011, 03:43 AM
bigFOIG's Avatar
Fan blade touching a wire or something?>
hooked up tv sound out to sound card in but I don't hear the TV Shadowmeph Audio 1 September 18, 2009 10:41 AM
Weird Speaker/On-Board Sound Problem... mitchelt Troubleshooting 1 August 25, 2009 06:13 PM
Worth it to buy a sound card or will MOBO sound be enough? Sandro_Bit CPU's and Motherboards 18 August 22, 2009 09:44 AM
Installed sound card, but no sound jcmaz Troubleshooting 5 June 22, 2009 12:39 PM
Creative Sound Blaster X-Fi Xtreme Audio is not really a X-FI sound card dirtfarmer Audio 15 January 2, 2008 08:15 PM
