-   -   Accident :( (http://www.hardwarecanucks.com/forum/new-builds/49839-accident.html)
taimoorali007 December 29, 2011 03:03 AM
Accident :(
Hi guyz,
Yestarday i was in the market to purchase Core i5-2400 but it was short and no chances for next 2 weeks but i then got Core i5 2320, but m not happy as it is lil bit below the line according to some specs:
vPro Technology: i5 2400 Yes i5 2320 No
Intel® Virtualization Technology for Directed I/O (VT-d): i5 2400 Yes i5 2320 No
Intel® Trusted Execution Technology: i5 2400 Yes i5 2320 No
Bus/Core Ratio: i5 2400 31 i5 2320 30
Embedded Option Available: i5 2400 Yes i5 2320 No
Will it make some major differences in terms of gaming video rendering casual work surfing internet and photoshop???????
Dzzope December 29, 2011 04:20 AM
Yes it will make a difference, thing is how much for the cost.
You can only decide if it's good enough.
taimoorali007 December 29, 2011 04:57 AM
If its better than i3 2100 then its ok, cuz soon maybe after 2-3months, ill purchase i7 2600k, then wat u say?
moocow December 29, 2011 05:26 AM
Then what's the problem? You already purchased the chip and pretty much stuck with it. For sure it's better than an i3-2100 since it got more cache and can turbo boost. In a few months, you can probably buy a i7-3xxx (don't know if you need a new motherboard).
AnandTech - The Sandy Bridge Review: Intel Core i7-2600K, i5-2500K and Core i3-2100 Tested
enaberif December 29, 2011 06:21 AM
Why not just keep what you have and save your money?
taimoorali007 December 30, 2011 07:16 AM
Yea, ryt and i7-2600k will be more enough and m aint going for extreme series as i just want good enough high end pc. So i should stick with i5
taimoorali007 December 30, 2011 07:18 AM
And yea i will also buy z68 board, maybe by MSI or Asus!!
Hmm, Thnx thnx guyz for ur help!!
Seriously, guyz i can get any typ of solution here! ;)
nyc work:punk::thumb:
Dzzope December 30, 2011 07:26 AM
If your going to get a 2500k or 2600k anyway then stick with what you have.
taimoorali007 December 31, 2011 02:21 AM
ROger That Sir!!:thumb:
