Old December 27, 2011, 04:39 AM
so what i decided is to buy a new system....
definitely x79 chipset motherboards...(maybe g1 assassin 2 )
but problem is the current cpus that released from intel so far , is very expensive and intel delayed for releasing other lga2011 until 2012....
i'm planning to buy 3930k.... but very expensive.... waiting for upcoming cpu for LGA 2011.
Old December 27, 2011, 05:19 AM
supaflyx3's Avatar
You'll be paying a pretty penny for any 2011 CPUs, if you want something under 500 go for a 2600k, or 2500k if you're only gaming.
Old December 27, 2011, 09:41 AM
yes only gaming.... (hardcore gaming )
but i want to pick x79 motherboard ( only LGA2011 socket)
which model you suggest me on this socket ?
because i want to buy either gigabyte (g1 assassin 2 / or x79ud7 oc )
so whats your opinion ?
because i want to buy highest end (and also future prooof system ) ! so buying newer platform (x79) is wisely ....
which cpu you suggest me (gamng and under 500$) ?
Old December 27, 2011, 10:03 AM
Unless you know of your own sources, you can't get a LGA2011 processor for less than $500.
Newegg.ca - Computer Hardware, CPUs / Processors, Processors - Desktops, LGA 2011
Intel Core i7 3930K 6 Core 12MB 3.2GHZ Hyperthreading Unlocked LGA2011 Processor No HSF - Intel - BX80619I73930K
I suggest you wait until the Core i7 3820 (quad core) is available if you really want LGA2011. By then you should also have more options with GPUs.
If you're building now, you can get a Z68 motherboard + either the Core i5 2500k or Core i7 2600k. For gaming only I'd suggest the 2500k as there is no game that can use 8 logical cores effectively and the extra 2MB of cache won't make a difference (the GPU will bottleneck long before then).
Old December 27, 2011, 11:58 AM
thank u for your advise .
you said about bottleneck . which side of bottleneck you are talking about exactly ? ( remain unused performance... or lack? )
describe more pls.
Old December 27, 2011, 12:21 PM
Wurmer's Avatar
For gaming the 2500k, 2600k or 2700k are plenty enough you really don't need the newest high end CPU for that. The best bang for the buck right now is probably the 2500k with a decent cooling system it can be easily overclocked. Even at stock speed this CPU is a power house, coupled with a good graphic card there won't be any games that you won't be able to play at max settings.
Old December 27, 2011, 12:22 PM
supaflyx3's Avatar
Don't even bother with X79 if you're only gaming. You won't see any benefit over a 2500K.
Old December 28, 2011, 08:19 AM
You mean x79 is more than gaming ? when there is a newer polatfrom why should i buy older (i mean z68)...
but problem is x79 cpus are very limitted and very expensive.... other lga2011 cpus will not release untill 2012...
  #19 (permalink)
Old December 28, 2011, 05:37 PM
if you game only you don't need anything more than 2500k. The LGA 2011 setups are for other stuff than gaming, like working, video editing, or scientific calculations, like Folding at Home, or simulations like Matlab. You could keep the current setup and try a videocard like Radeon 6950/6970 or GTX560/Ti/GTX570 if that does not work then you keep the new videocard and change the rest of the system too. If you take a new mobo with more than one PCIE X16 slots you could also keep the GTS250 as PhysX processor, no matter what card you will add, nVidia or AMD.
  #20 (permalink)
Old December 29, 2011, 04:54 AM
To be completely honest, drop in a new card and see how you go... if your still not happy then consider replacing the rest.
Pretty much everything out will be fine on that processor (BF3 is hard on it so may be an exception)
Build and configure system for gaming! with 1200-1400 for only system! a_2008 New Builds 2 November 24, 2011 05:38 PM
What are those pins and connectors on the mobo called? bkh2 Off Topic 5 July 7, 2011 12:55 AM
does anyone know what these are called BrianHanna Off Topic 13 October 29, 2010 04:12 PM
TechNet Just Called. Told Them I'm Home User geokilla Off Topic 11 October 19, 2010 01:44 PM
need a topic called NAS boxes cmak Suggestions & Feedback 0 May 8, 2009 08:57 PM
