Old December 24, 2011, 02:39 AM
+1 on waiting for the ivy bridge. Or just buy a used, the SB/ lga1155 system is relatively new so if you can find some deals on a used mobo and cpu ( as long as it has the original box/serial number and heatsink for warranty ) your good to go. Most of the used motherboards/cpus probably have 2 years of warranty left since it goes by date of manufacture. The other parts you can buy used as well to save some serious $ $ $ $. There are plenty of used i5 2500k systems on kijiji.
HAF 912 painted / new build i5-2400 bonanza2000 New Builds 5 April 24, 2011 11:15 AM
Server Build Parts Check Arinoth New Builds 1 March 24, 2011 02:57 PM
First ever build for me, buying parts in 1 week, need advice. Heartattaq New Builds 14 March 17, 2011 04:01 PM
Buying PC Parts from the US Goalieman077 Off Topic 8 October 14, 2009 12:22 PM
My first build; need someone to double check my parts Fenrise New Builds 15 August 17, 2009 08:00 PM
