Old December 19, 2011, 01:44 PM
Default Help with 1st build
I am completely noob at building computers so what in order should I do after I plug everything in?
Example
1.OS
2.graphic card drivers
3.etc
This might be a really noob question tho.
Old December 19, 2011, 01:52 PM
great_big_abyss's Avatar
Once everything is assembled and your computer posts when you turn it on, the first thing is to install your OS. Then you install all your drivers starting with your motherboard.
Old December 19, 2011, 02:21 PM
martin_metal_88's Avatar
If you are using Win7, you will be able to go on the web without installing any driver. I strongly recomend to go on your manufacturer site to get the latest driver and if you can ( like you GPU ) go on ATI on Nvidia site instead of the card brand site. Brand driver are usually full of crap and pub while Nvidia and ATI direct driver are just clean driver.
Old December 19, 2011, 03:14 PM
1. Install the OS
2. Make sure you set up your Wifi (Optional - If you don't have LAN Cable)
3. Download Graphic Drivers from Manufacturer Website AMD - (AMD Graphics Drivers & Software) or nVidia - (Drivers - Download NVIDIA Drivers)
4. Restart PC
5. Install Sound Drivers (If you have additional Sound Card)
6. Install Webcam Drivers (Optional - If you have it)
7. Install Keyboard & Mouse Drivers (If You have a customizable Keyboard or Mouse)
8. Restart PC
9. Do Windows Update (Type in 'Windows Update' in Start menu)
10. Restart PC
11. Do Windows Update Again - To make sure you got everything
12. Restart PC
That should be everything unless you want to list all your components for a more in-depth guide
To build, or not to build: that is the question Timid newbe New Builds 5 August 12, 2010 04:33 AM
New Build- Corsair 800D --> My cleanest build ever. Watercooled btdvox Case Mods, Worklog & Gallery 28 May 11, 2010 01:07 PM
Windows 7 Build 7000 VS Windows XP SP3 Build 2600 Benchmarks Veritas Overclocking, Tweaking and Benchmarking 3 March 3, 2009 02:48 PM
