  #21 (permalink)
Old December 15, 2011, 07:48 AM
great_big_abyss's Avatar
Building a computer for the first time is a process that REQUIRES you to read the instructions BEFORE you do anything. It's not like replacing a starter on a car where you can screw up and it will still be okay. Computer parts are very delicate and very expensive.
Most motherboards come with very detailed step-by-step instructions, c/w pictures. Use them.
On a side note, I wish you luck trying to RMA your board. Manufacturers and Dealers don't typically replace parts that have been broken by bad installation.
  #22 (permalink)
Old December 15, 2011, 02:58 PM
I'll tell them UPS might have damaged it when they delivered it. When I took out my case it was chipped where one of the PSU screws go in...
  #23 (permalink)
Old December 15, 2011, 03:12 PM
Like I said, I sincerely wish you luck. If they do RMA it and you get a new board, please oh please follow the instructions. Computer building is really not hard at all if you just go step by step as per the motherboard instruction manual. It wouldn't hurt to take a look at your case instruction manual, too.
  #24 (permalink)
Old December 15, 2011, 04:45 PM
Apevia and my gigabyte board were pretty confusing. But I still haven't run this thing on a monitor yet! I think it's because no OS is installed and that could be the reason. I'm getting an hdmi soon and I'll see how it goes.
I'm sorry if I seem jumpy, i'm 15 and I am a first time builder. I am one of those people who like to do stuff then read manuals.
  #25 (permalink)
Old December 15, 2011, 05:55 PM
Everyone has to learn the hard way, I suppose.
  #26 (permalink)
Old December 15, 2011, 07:11 PM
KaptCrunch's Avatar
took the long road ,,,,,,,,short is READ manual
