Old December 12, 2011, 04:35 PM
in stereo no less. :-P
My stuff for sale.
Mah Rig
Old December 12, 2011, 04:44 PM
Originally Posted by clshades View Post
you need to short the power switch pins on the mobo headers with a flat head screw driver. The motherboard isn't going to turn on by simply turning on the power switch to PSU.
You can also use the case power button just plug it into the correct place and push the button.
I plugged the reset switch and power switch into the correct slots in the mobo.
The mobo was plugged to the big pin thing and the 12v. The motherboard was in O , I turned it to I.
Then I turned on the power button on my computer and the fan of the PSU was working.
Old December 12, 2011, 04:48 PM
The big pin thing you are refering to is the 24pin connector and the 12v is either a 4 pin or 8 pin.
I'm assuming it's working...
My stuff for sale.
Mah Rig
Old December 12, 2011, 05:39 PM
Uh oh :(
It's not working again!
So the PSU was working, fan was spinning , reset and power switch were plugged in.
I unplugged everything, put the mobo in my case, put the PSU in my case , hooked up my dvd r/w, hdd and then it doesn't power on!
Should I just send it in to a friend to build it for me? That would be my last case scenario.
Old December 14, 2011, 08:06 PM
I need help again!
This time I got everything hooked up! Reset and power switch in the front panel.
I turn it on , it stays on for about 45-60 seconds and then it turns off. Then it turns on by itself.
Is it stuck in a reboot? Is the PSU bad? It's a coolmax 600 Watt ( I had to meet budget). Case is an Apevia x-trooper JR(I know it's small).
Thanks for the help!
Old December 14, 2011, 08:08 PM
I need help again!
Also my video card hasn't even come yet!(GTX 560ti)
And when I plug the case USB and Audio into the ports in the case, it'll turn on for about 3 seconds and just turn off. It won't turn back on.
Old December 14, 2011, 08:13 PM
Pull out the board and check your standoffs to make you only have what is needed.
Old December 14, 2011, 09:04 PM
There was only one standoff that was on the case that didn't need to be. But it didn't touch the mobo at all.
I think I know what I did wrong.
Well I didn't know what standoffs were until now..So I put the mobo in the case without them yesterday and I might have damaged the board?
But it still does that reboot thing even with the right stand offs in.
  #19 (permalink)
Old December 14, 2011, 09:07 PM
No offense it sounds like you should have either had someone show you or had someone do it.
  #20 (permalink)
Old December 14, 2011, 09:09 PM
It was my first build alone and I'm one of those people who just wing it. I don't really read instructions until I really think I need them, I thought the stand offs were not that significant.
My mistake.
I'll probably send it back to TigerDirect and get a new one if it's not usable now.
