It depends on the specs of your rig. If it is a rig that you are going to do some overclocking with then it is a worth investment to spend on higher performing RAM. If your rig has no overclocking potential at all (locked) then Value RAMs works just fine. However, if you're looking for some substantial performance boost from upgrading your RAM then steer away because the difference is little at best.
