Old December 2, 2011, 02:01 PM
Based on all the advises I got, I think my refined build would probably be like this
Mobo: asus p8z68 v-pro
CPU: i7 2600k
GPU: asus gtx560 dcII oc
PSU: corsair HX650
HDD: some WD 1TB
SDD: Intel 80gb 320 series
Memory: kingston 4gbx2 8gb 1600mhz hyper x
Cooler: Noctua NH-D14
these would probably be my build, so now there is one left, casing. Is there any casing recommended from you guys? I am worry of the Noctua cooler can't fit it as it seems quite big to me. I was plan to get cooler master USP 100 or elite 430.
Old December 2, 2011, 02:14 PM
GT7R's Avatar
Get a HAF 912 or a Corsair 400/500R.
The build looks solid, just make sure the GPU is a 560Ti.
Old December 2, 2011, 03:01 PM
I am concern that whether a Noctua NH-D14 can fit into HAF912 with fans on the top? I've done some research on it and some said it fits well because it fits Silver Arrow and Scythe S-Flex fans which has similiar size to NH-D14 ( I guess? ). but I am worry about will it affect the airflow in the system?
Old December 3, 2011, 03:41 AM
GT7R's Avatar
The only direction where the NH-D14 is problematic is the RAM and mobo heatsinks, It'll fit with the case fans just fine with enough room to spare.
Old December 3, 2011, 05:03 AM
It's not a big deal if you could not fit regular sized fans at the top, thinner fans could be placed at the top. Remember, hot air rises or whichever direction there are exhaust fans, so there is no need to worry about the airflow. I would prefer to get the 400R if I were you, my personal choice.
Old December 3, 2011, 06:18 PM
I've decided to get Corsair 400R and fit NH-D14 in it, hopefully it is fit
Co-op Gaming Advice Arinoth Gaming 30 January 13, 2012 12:35 PM
Advice on new Gaming Pc Thepigthatflew New Builds 10 August 12, 2011 09:33 AM
Advice on Gaming PC awirthy New Builds 13 March 18, 2011 08:07 PM
New gaming pc advice kanadien New Builds 12 December 14, 2010 12:57 AM
mid gaming for $600 need advice leland459 New Builds 7 July 15, 2010 08:40 AM
