Old November 30, 2011, 07:08 PM
Default iT'S ALIVE!!! DING DING ROUND 2!!
HAPPY!!
FAN CONTROLLER ON THE H100 DIED DEAD!!
NH-D14 INSTALLED!! EASY AS PI!!!
THX TO ALL THE HELP FROM HC'rs!!!
JP
Old November 30, 2011, 07:22 PM
Moneyless's Avatar
Very nice rig you've got there.
"I hate broccoli
And think it totally sucks
Why is it not meat?"
-Deadpool
Old November 30, 2011, 07:35 PM
supaflyx3's Avatar
Case looks a lot sexier then i had presumed, On my buy list now...
Old November 30, 2011, 07:38 PM
Birk's Avatar
i see you got 4 sticks of ram running on that board. what spec? did you have to change anything? I've been told running 4 sticks on these boards can be tough and i've got a 16gb kit here I'm wanting to run when my CPU gets here this week.
Old November 30, 2011, 07:44 PM
supaflyx3's Avatar
Where did you hear that?
Old December 6, 2011, 07:48 AM
Default ???
never read that anywhere??
sup wit dat?
no issues that i'm aware of...
fans died on Sunday...
JP
Old December 6, 2011, 08:25 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
This is OT but since its been brought up....
In theory running four sticks on a dual channel rig is no problems. However, just like the 1366'ers and running 6 sticks on triple channel it can cause issues. It can also limit some overclocking ability. BUT even for normal peeps needs, four sticks can - from time to time - cause some wonky issues to pop up. It is rare and most people never have issues, but it does happen. Especially when a newcomer purchases two dual stick kits and didnt configure them properly in the BIOS. Even when properly configed it can happen.
Hell my test bed - and it looks to be that same mobo as the OP - ran into issues with Mushkin and then GSkill....but loved Corsair that I fed it. All 8 sticks tested fine and are working perfect in other rigs...but not that particular mobo. Just like in the old days the very first thing I do when TS'ing and tracking down memory related gremlins is pull two sticks. IF the problem goes away...it was the sticks not playing nice (assuming that the test fine on a dif rig and its not just a dead stick or dead ram port on the mobo). IF the gremlin is still there. Pull another stick and try them one at a time. Classic computer trouble shooting 101.
To the OP sorry to hear about your H100. Corsair are good peeps to deal with and will make it right. In the mean time...yeah that air cooler you have chosen to replace it with...is a beast. You will love it.
Old December 6, 2011, 10:19 AM
Default RE: THE BEAST!!
THX AKG!!
JP
Old December 6, 2011, 12:03 PM
Actually true. There's a pretty simple workaround that usually works to stabilize.
1) set your memory voltage (usually either 1.50v or 1.65v), speed (1333, 1600, 1866, etc., sometimes by way of a mulitplier of 100.) and timings MANUALLY (at least the 'big 5' timings, like 9-22-9-27-2T in my case). Do not leave ANY of these settings on 'auto'.
2) bump up the vtt/vccio. Stock is 1.05v. Generally accepted day to day safe is considered 1.20v. There is one report that Dell systems use 1.30v at stock. I run mine at 1.15v day to day.
Not necessary for every system configuration. But if you aren't stable or getting funky crashes, try it.
2600K @4.6 for now, still tweaking.
P8Z68-V Pro Gen3
Patriot Div2 Viper Extreme PC3-15000 4GBx2 (1866 9-11-9-27-2)
EVGA GTX 580 SSC
Caviar Black 1TB x2 RAID0
Corsair Gold 850W
Corsair H80
Corsair 600T Graphite
Old December 6, 2011, 07:16 PM
Default BEST PWM FANS??...NEED HELP!!
now i will be the first to admit the looks of the Noctua Fans is something left to be desired.
that being said, they are relativley quite, and floating around 1200rpm.
however, the Thermal right PWM fans are KICKING ASS!!!
i think im going to swap out the Noctua fans for the TY-140's and see how she runs.
anybody have more experience with either of these fans?? please feel free to chime in and give some additional insight.
thx
JP
It's Alive! prokaryote HardwareCanucks F@H Team 12 January 26, 2012 07:05 PM
She's Alive... redwagon HardwareCanucks F@H Team 6 September 16, 2009 06:40 AM
It's alive!!! It's ALIVE!!! IT'S ALIIIIIIIVVVEEE!! cadaveca Off Topic 14 June 7, 2009 12:01 PM
Microsoft may keep XP alive after all stoanee Rumor Mill 55 November 5, 2008 01:57 PM
It's alive, even after I shut down. misterd Troubleshooting 13 August 19, 2008 05:55 AM
