Old December 1, 2011, 01:22 AM
Dzzope's Avatar
Case is personal choice and i don't know that particular one.
I think it's expensive for your budget, and Really ugly (personal taste, whatever your happy with).
Mobo, z68 over p67, If you'll use the SSD caching, PCI-E 3.0 and integrated CPU graphics it's great, if not get the p67.
p67 is a great board if slightly older, allows you to clock well and is quite a bit cheaper.
There is a third option if your not going to oc at all (again chose a non k cpu) that won't allow you to oc and is very cheap but I believe in getting the good bits at good prices (p67 is very good for price and performance).
GPU, 6950 is torn a new one by a 570 or a 560ti 448 but is also slightly cheaper. it's about the same performance as a 560ti but with more ram than you'll ever need.
I would suggest the cheapest 5970/570/560ti448 you can get your hands on. as long as it is more than 1 GB you should be looking pretty good for gpu ram for a few years at 1920x1080
Old December 1, 2011, 04:43 AM
Bond007's Avatar
Its all pretty good. I am not familiar with the case though. And the ram needs to be changed to a 2x4gb or 4x4gb kit...no point in 3 sticks of ram since its a dual channel memory MOB/CPU.
Old December 1, 2011, 03:59 PM
Thanks for picking up the mistake about the dual channel memory, I must have been really tired when choosing these parts.
Anywho, I was wondering if you could tell me the difference between the CMZ8GX3M2A1600C9 8GB (2x4GB) and the CMZ8GX3M2A1600C8 8GB (2X4GB) ? Is it just the latency and is it worth the extra 10 AUD?
Thanks Steve
Old December 3, 2011, 06:41 PM
Dzzope's Avatar
Originally Posted by Dzzope View Post
3x4GB?
Sandybridge don't have tri-channel ram. 2x4 GB should be plenty for your needs but if not you can get another 2x4 gb in the future for an easy and relatively cheap boost.
I doubt you'll see the difference to be honest. It's more for enthusiasts and people who will be clocking / benchmarking etc. Performance gain will be minimal at best and you will probably not/barely see anything even if you had 2 machines side by side that were identical bar the ram.
First Computer Build k__dizzy New Builds 10 January 11, 2011 06:54 PM
First computer build (HELP) ssandulak New Builds 42 December 24, 2009 07:27 PM
New Computer Build Jeremychan17 New Builds 33 April 7, 2009 12:22 PM
First Ever Computer Build Wein13 Case Mods, Worklog & Gallery 49 September 19, 2008 03:54 PM
Build Me A Computer IronBubbles New Builds 20 August 23, 2008 07:39 PM
