Old November 28, 2011, 05:58 PM
Default Sandy bridge build
Looking at building a sandy bridge machine for around $1200 -I dont need a psu or video card. Gonna be suing the pc mostly for gaming. i already have a gtx 580 and a 1000 watt corsair psu.
Would like to get an 120gb SSD if could and then use my old WD 1tb black to go along with that.
I will be ocing this machine.
any suggestions would be great thanks in advance
Old November 28, 2011, 06:55 PM
What are you currently running?
With that GPU and PSU, would I assume that either something has blown-up or ??
Ivybridge in a *few* months, if you machine isn't BAD or dead then I'd wait.
Old November 28, 2011, 08:52 PM
techman95's Avatar
what do you have now do you want p67 or z68 do you edit, render or record? is it just gaming? we need more info.
Amd....definitely a blond female.....not much on the cpu side, but always strutting about showing off her gpus
Old November 29, 2011, 07:03 PM
well the current situation is that i am going to be giving my current machine (i7 860 oced to 4ghz, 8 gigs ram, 500gb wd and 1 tb wd HDDs. gtx 580 inside a haf 932) to a family member. So that is why i am building anew a machine.
gonna be using it almost exclusivily for gaming, at 1920x1080. i was kinda leaning towards a z68 just because they were newer and had the pcie 3.0x supports and all that jazz but laso it seems thye are harder to overclock as well so now i am not sure.
im not sure which way i should go lga 2011 or lga 1155. again its gonna be used for pretty well only gaming but i would like to get more performance out of it then my current set up.
Old November 29, 2011, 11:35 PM
For gaming at that res a quad core Phenom would be sufficient..
Is the GPU and PSU the ones from that box? What is the family member going to use it for?
I might suggest that you spend less and build the family member a cheaper system/ buy them a second-hand one as the current one you have is far from bad. and saving money now will allow you to jump to Ivybridge as soon as it's out.
Old November 30, 2011, 08:09 AM
Eldonko's Avatar
Hardware Canucks Reviewer
For a gaming build with that budget I would probably go with a 3930k and a G1 Assassin 2. Built in NIC and soundcard, 12 threads of processing power, and 40 PCI-E lanes in case you add a second 580 down the road.
Old November 30, 2011, 09:02 AM
GT7R's Avatar
Why not a Sabertooth for a mobo?
Old November 30, 2011, 09:06 AM
Eldonko's Avatar
Nothing wrong with Sabertooth but for an extra $70 you can get X-Fi and Killer E2100 which are great for gaming if you dont have a NIC and soundcard already.
Old November 30, 2011, 09:16 AM
2500K or 2600K + I recommend ASUS for the Z68/P67 boards.....almost any of them will be great performers. You'll need cooling to overclock, so budget something for that. You can get a great mobo + 2500K + 8G memory for under $500, so you have plenty of headroom here. $100 for an H100 cooler, $150 for a case, $200 for an SSD = $950.
As to X79, let's see, roughly:
$300 for mobo
$600 for 3930K
$? guessing $100 for 4X mem kit, might be light there
$150-200 for SSD
You might get there for $1200, given you have a good PSU and vid card. Probably doesn't get you a case or upgraded cooling though.
2600K @4.6 for now, still tweaking.
P8Z68-V Pro Gen3
Patriot Div2 Viper Extreme PC3-15000 4GBx2 (1866 9-11-9-27-2)
EVGA GTX 580 SSC
Caviar Black 1TB x2 RAID0
Corsair Gold 850W
Corsair H80
Corsair 600T Graphite
Old November 30, 2011, 09:36 AM
HOTDOGS's Avatar
Restricted Poster
i5 2500k
Asus P8P67
120gb SSD for boot
Use your WD Black as your storage drive, maybe for games
8GB Corsair Vengeance
Coolermaster Cm 690 II Advanced
Throw more money into a better case or more ram if you want. other than that, you'll stay way under budget and could invest your money into another monitor, a soundcard, better headphones/speakers or just save it. That's what I would do for a gaming setup. Maybe look into an SLI board and pick up a second GTX 560 and keep the rest the same.
New Sandy Bridge Build. von Monster New Builds 18 August 6, 2011 05:06 PM
Optimizing new Sandy Bridge build hobo_crew New Builds 10 March 29, 2011 12:00 PM
Sandy Bridge build, need advice? trippindeath New Builds 10 February 1, 2011 12:12 AM
First build, Sandy Bridge Atmax New Builds 6 January 26, 2011 02:46 PM
My Sandy Bridge Build Eluder New Builds 24 January 17, 2011 05:42 PM
