Old November 28, 2011, 03:27 PM
Default Rate this build.
Gaming(BF3, Skyrim, TDU2, Need For Speed, Minecraft), Video Editing, Photoshop, media.
Around $800 give or take $50
United States
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
Intel, swaying to the nvidia side but I like the 6950
Media Reader
Not sure what this means
Really depends. Quite possible
Buying it by the end of this week
9. What resolution do you use?
1366x768, will be played on 32" coby TV.
__________________________________________________ _________
i5-2500k
GTX560ti or Radeon 6950 1gb
8gb DDR3 1600 mhz ram
Biostar Z68 ATX LGA 1155
630w continuous 80+
Seagate 1tb 6gb/s 7200 rpm
Maybe a HAF912 case
Q2: Will this run Skyrim and BF3 on highest settings with NO AA at 1366x768?(It'll be on my 32" Coby TV, it says 1366x768 but I'm not good with TV's)
This is my first build. I have been interested in computer since 2009 and I am 15 now.
Current PC specs:
AMD Athlon LE-1620, 2.4 ghz 1 core
250w psu, not sure of the brand
not sure of the motherboard brand
3gb DDR2 ram. 2gb 500 1gb 667
Nvidia Geforce 6150se nforce430 128mb
140gb 7200rpm Hitachi harddrive
I know what I'm doing, I researched parts for about a year and I participated in a build once. Yes, I am a computer lover who has an old prefab lol.
Last edited by IntelRocks; November 28, 2011 at 03:57 PM. Reason: Fixing for the needed part..
Old November 28, 2011, 03:30 PM
Birk's Avatar
Looks good to me except I'd grab the Asus p8Z68-v Pro for a MB but that is my personal preference
I don't see any issue with running BF3 or Skyrim with that. if anything would hold you back it would be the GPU but I think you have it covered with the 560ti. Somebody will correct me if i'm mistaken on that.
Old November 28, 2011, 03:40 PM
$205 is a lot to spend on a budget build. I could wait until May to get a new computer(My mom graduates from RN school) and my budget will rise about $250 but my computer blue screened a few weeks ago. And it is running really loud even just browsing the internet so I really have no choice to get it now.
But I need it to take me through highschool, I don't want to skimp. It's now or never, my computer will be 4 years old in 4 months. I'm a gamer, you should know what I've put this thing through lol.
I'm going to stick with the biostar. It has everything I need, 1600mhz, USB 3.0, LGA 1155.
Flow Rate? MattC Water Cooling 7 August 10, 2011 10:24 PM
Rate my psu(s) choice.... 4DoorGTZ Power Supplies 8 July 12, 2011 06:07 PM
rate my amd build plz megagabobe1 New Builds 9 April 10, 2011 10:27 PM
Rate my computer build? :) Skead New Builds 15 August 5, 2008 02:20 PM
Hey HWC, rate this build! Khronos Off Topic 9 December 17, 2007 02:12 PM
