Old November 27, 2011, 06:48 AM
Trial Member
Default Need Advice Please
Im am soon to be getting a new pc. I have built it on pcspecialist.com but i would like some advice on whether the pc is good for gaming, whether there will be any bottlenecks and what fps can i expect on games.
PC Specs:
Intel Core i7-2700k Quad Core @ 3.5ghz
ASUS P8Z68-V/Gen3 Motherboard
16GB Ram
1.25GB Nvidia Geforce GTX 570
2TB Hard Drive
12x Blu-Ray Drive, 16x Dvd Drive
600w PSU
Windows 7 Home Premium 64bit
All Help will be greatly appreciated
Old November 27, 2011, 10:57 AM
Your pc is perfect for games and you can run any game out there. Save some money for a SSD and you will be fine.
Old November 27, 2011, 12:48 PM
There may be a few parts there that are overkill if you are building the computer for gaming.
The i7 2600K is only slightly faster than the i5 2500k, both have 4 cores, although the i7 is hyperthreaded and so can pretend to have 8 cores. As such, the $100 price increase to go with the i7 is totally not worth it, if you don't need the hyperthreading (ie: if you are gaming).
The 16 GB RAM may be cheap so why not, but I have 8GB and never seem to get close to capping it out.
In any case, that build should be great for most any modern game at max settings (1920x1080 monitor).
If you save money on the downgrades I suggested, I would look at a video card with more Video RAM, or an SSD for faster boot and load times.
Old November 27, 2011, 01:44 PM
GT7R's Avatar
IMO for gaming, investing more in a good GPU is wiser than on an SSD.
Old November 27, 2011, 02:15 PM
Its good to go. As mentioned above, if its strictly a gaming rig I would save the money and go for 2500k, but that's your call. Also make sure its a quality power supply (you didn't mention any brand/model/etc).
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old November 27, 2011, 02:38 PM
I would agree with these points, especially about the CPU because the OP has suggested a i7 2700k which is definitely overkill. I would say get the i5 2500k and put that money into the GPU.
Old November 27, 2011, 05:52 PM
get a 2500k, and 8gb is more than enough for gaming, and because ram is getting cheaper and cheaper like every month, wait till you find 8gb is not enough then pick up another 8gb. Spend the money saved on an ssd
Tags
advice , gtx 570 , intel core 17 , new build , new pc
Need some advice HiTi New Builds 4 January 9, 2011 02:45 PM
gpu advice CTA Video Cards 23 December 29, 2010 01:44 PM
PSU Advice Soultribunal Power Supplies 27 December 14, 2009 02:38 PM
OS advice... somecanadianguy O/S's, Drivers & General Software 18 October 9, 2009 08:20 AM
BAH, looking for some advice again... Neolithium_Wpg Video Cards 5 January 12, 2009 08:15 PM
