Old November 25, 2011, 02:32 AM
this site wont let me upload the pic sorry
Old November 25, 2011, 07:29 AM
Ram loops are the most pain in the ass thing to do out of any water loop.
Don't bother with he ram as its generally the one piece of hardware your gonna change out a lot over time.
Old November 25, 2011, 10:30 PM
Ive found out that this is a veriation of the Koolance Ram-35
But if any one knows where i can get this on from or another system that links kind of like this let me
know.
Also if anyone knows what the actual products name is
thanks
Old November 25, 2011, 10:47 PM
rjbarker's Avatar
As Enab and others have pointed out...you shouldn't get all hell bent on WC the RAM, the CPU, Chipset and GPU's (especially multiple 580's...as in 3) are going to have you up to your knackers in WC gear.....one of our Members here put together "Black Widow"...full on WC'd in a HAF X, I know what he would say if someone asked him "why" he neglected to WC his Memory ;)
Firestrike Extreme: 21.452
MARK 11: 32.530
Old November 25, 2011, 11:50 PM
SugarJ's Avatar
Water Blocks - Ram : Performance-PCs.com, ... sleeve it and they will come
Koolance 35 is about half way down the page.
Old November 26, 2011, 12:33 AM
Success ive finally found what the product is. Its the Koolance RAM-30-V06
If any one knows where i can get this ram cooler i would be extreamly greatful
Old November 26, 2011, 04:49 PM
JD JD is offline
I would not recommend buying a waterblock that is 6 years old.
Why not consider something more recent like these:
MIPS RAM Cooler 4 incl. 4 RAM Module Nickel Products Model: PH-19025 [PH-19025] : Performance-PCs.com, ... sleeve it and they will come
Bitspower Universal RAM Module Water Cooling Set For 4 Banks 4-DIMMs - Clear/Black Products Model: BP-RAMS44-CLBK [BP-RAMS44-CLBK] : Performance-PCs.com, ... sleeve it and they will come
Old November 26, 2011, 05:53 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Honestly, why do you want to cool your ram? Ram - even overclocked ram - just donest run that hot and even a minor amount of active cooling will keep them VERY happy. Hell at moderate OC's ram is just fine with PASSIVE setups where your case's internal air flow is more than enough.
IF you are hell bent on it...you are in for pain. You will be introducing a crapton of flow restiction and all round pain in the arse factor to your loop. I did it ONCE....and never again.
YMMV
  #19 (permalink)
Old November 26, 2011, 06:09 PM
JayDeeHobbit's Avatar
Besides the performance aspect of things H20 can LOOK cool.
And the looks are probably more important these days for putting H20 on RAM. I sure wouldn't want to do it but "to each his/her own".
"Try looking into that place where you dare not look!
You'll find me there, staring out at you!" - Frank Herbert
  #20 (permalink)
Old November 26, 2011, 09:22 PM
JD JD is offline
By the looks of it, these newer blocks merely sit on-top of heatspreaders. So the block itself isn't very restrictive I'd say. But like you said, cooling wise, it isn't doing much.
Tags
help with parts , koolance , ram , water block , water cooling
[WTB] product finder link? elninio Buy/Sell & Trade 0 March 15, 2010 11:51 PM
Do you register an RMA product? redwagon Troubleshooting 5 November 24, 2009 03:58 PM
Vista How-To: Product Key Already In Use Fix Supergrover O/S's, Drivers & General Software 11 August 24, 2007 07:57 PM
