Old November 21, 2011, 05:46 PM
Default X58 or x79? Need help on building a new build ( RESOLVED )
Hello, I am wondering wich one i should get, the x58 or x79. What i want in my build is this: GTX 590, 1000 watt power supply, NZXT Phantom full tower case, on the x58 4go x 3 of ram on the x79 4go x 4, blu-ray, asus rampage III extreme on the x58 and prx79 delux on the x79, i7 980 on x58 and 3930k on x78. Both come up to the same price and i am wondering which one i should buy.
Thank you very much for your help!
-------------------------------X79------------------------------------------------------------------
Case----------------- 1 x NZXT Phantom Full Tower Gaming Case-Red
Processor------------- 1 x Intel® Core™ i7 3930K Processor (6x 3.20GHz/12MB L3 Cache)
Motherboard---------- 1 x [3-Way SLI] ASUS P9X79 Deluxe -- 2x Gb LAN, 4x PCI-E x16, 4x SATA 6Gb/s, 4x USB 3.0, On-Board Bluetooth
Memory-------------- 1 x 16 GB [4 GB X4] DDR3-1600 Memory Module-Corsair Vengeance
Video Card------------ 1 x NVIDIA GeForce GTX 590 - 3GB-Single Card
Case Lighting--------- 1 x Cold Cathode Neon Light-Blue
Power Supply--------- 1 x 1000 Watt -- Extreme Gaming Series
Processor Cooling----- 1 x Liquid CPU Cooling System [SOCKET-2011]-[Free Upgrade] Standard 120mm Fan
Video Card Brand------ 1 x Major Brand Powered by AMD or NVIDIA
Primary Hard Drive----- 1 x 120 GB Corsair Force Series 3 F120 SSD-Single Drive
Data Hard Drive------- 1 x 600 GB WD Velociraptor HARD DRIVE -- 32M Cache, 10000 RPM, 6.0Gb/s-Single Dirve
Optical Drive---------- 1 x [12X Blu-Ray] LG BLU-RAY Re-Writer, DVD±R/±RW Burner Combo Drive-Black
Sound Card----------- 1 x 3D Premium Surround Sound Onboard
Network Card--------- 1 x Onboard LAN Network (Gb or 10/100)
Subtotal $3,127.00
-----------------------X58-----------------------------------------------------------------------
Processor------------ 1 x Intel® Core™ i7 980 Processor (6x 3.33GHz/12MB L3 Cache)
Motherboard---------- 1 x [3-Way SLI] ASUS Rampage III Extreme w/ 4x PCI-E 2.0 x16
Memory-------------- 1 x 12 GB [4 GB X3] DDR3-1600-Corsair Vengeance
Video Card----------- 1 x NVIDIA GeForce GTX 590 - 3GB-Single Card
Processor Cooling----- 1 x Liquid CPU Cooling System [SOCKET-1366]-[Free Upgrade] Standard 120mm Fan
Video Card Brand----- 1 x Major Brand Powered by AMD or NVIDIA
Primary Hard Drive---- 1 x 120 GB Corsair Force Series 3 F120 SSD-Single Drive
Data Hard Drive------ 1 x 600 GB WD Velociraptor HARD DRIVE -- 32M Cache, 10000 RPM, 6.0Gb/s-Single Drive
Optical Drive--------- 1 x [12X Blu-Ray] LG BLU-RAY Re-Writer, DVD±R/±RW Burner Combo Drive-Black
Subtotal $3,186.00
Old November 21, 2011, 06:17 PM
NI3 NI3 is offline
Definitely 3930K. Same price, better performance.
Old November 21, 2011, 06:33 PM
Soultribunal's Avatar
Thread moved to New builds, which is where it belongs.
-ST
www.realhardwarereviews.com
Old November 21, 2011, 06:50 PM
rjbarker's Avatar
Go with an X79 build.
Firestrike Extreme: 21.452
MARK 11: 32.530
Old November 21, 2011, 06:57 PM
I take it you're buying a custom pre-built PC? Doesn't look like you're buying parts and building it yourself.
Yeah, hands down the x79 with there being so little price difference. I'd only suggest the x58 to save some $$, but that price you quote isn't cheaper. If it's an option, go for the 240GB SSD and ditch the velociraptor for a normal 7200rpm drive. That way you can have everything that uses the speed on the SSD and save $$ to afford it by getting a slower storage drive.
Old November 22, 2011, 05:14 AM
I am buying a custom pre-built PC. I'm seeing that everyone recomands the x79! But what im scared is the motherboard... on the x58 i had a republic of gamers asus rampage three extreme which is pretty high end.. and on the x79 i have a normal but the really high end p9x79 delux. Would that effect any thing?
------------------------------------x79---------------------------------------------------------------------------------------------
Processor------------ 1 x Intel® Core™ i7 3930K Processor (6x 3.20GHz/12MB L3 Cache)
Processor Cooling------ 1 x Liquid CPU Cooling System [SOCKET-2011]-[Free Upgrade] Standard 120mm Fan
Primary Hard Drive----- 1 x 240 GB Corsair Force Series 3 F240 SSD-Single Drive
Data Hard Drive------- 1 x 500 GB HARD DRIVE -- 16M Cache, 7200 RPM, 6.0Gb/s-Single Drive
Subtotal-------------- $3,200.00
How is that?
Old November 22, 2011, 05:20 AM
Arinoth's Avatar
You know you could go with the new Extreme model that was reviewed by HwC just this past weekend here ASUS X79 Rampage IV Extreme Socket 2011 Motherboard Review . Take a look at it and see when your shop/builder will be getting them in stock.
Here I am: here I remain
Old November 22, 2011, 07:13 AM
I am buying it at ibuypower.com. I do not know how to check the release of the rampage 4. I would really like to have the rampage 4. But another thing i am scared of is the price difference between the p9x79 deluxe and the rampage 4. Is there any way for me to find out?
Old November 22, 2011, 07:19 AM
Arinoth's Avatar
Is there any reason why you are buying from them. You are aware you could buy parts for a system at NCIX, price match them to whoever has them on sale the cheapest, then for only 50$ have NCIX build and test it for you (the hardware, even Win 7 if you bought that from them too)
Old November 22, 2011, 08:35 AM
if you really need 6 cores get the x79
but if you gaming n stuff get a nice 2500k or 2600k
x79 is a waste of $ in my opinion
a freing bought a rampage IV n 3930K n just sold it after a few days
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Tags
asus , help with new build , new build , x58 , x79
Building Again fyshawk New Builds 0 May 9, 2010 06:00 PM
Building an HTPC - Critique my build! Andy New Builds 16 September 9, 2009 07:40 AM
Building right now... need a little help somecanadianguy New Builds 44 April 4, 2009 05:36 PM
Building New Rig swiftk1 New Builds 7 August 27, 2008 02:16 PM
Building another rig! Kassela Troubleshooting 5 March 17, 2008 10:14 AM
