Old November 22, 2011, 08:46 AM
If you're going with that budget, go X79. It's ridiculous that you'd spend the same for 3 year old tech. The X79 uses essentially the same cpu, with more cores, as P67/Z68, the benefits being more PCI lanes and 4 channel memory instead of 2 - as noted above me, you can get a lightning fast system for $5-700 less if you go 2500K/2600K. But unlimited budget, heck yes 3930.
2600K @4.6
P8Z68-V Pro Gen3
Patriot Div2 Viper Extreme PC3-15000 4GBx2 (1866 9-11-9-27-2)
Gigabyte GTX780
Caviar Black 1TB x2 RAID0
Corsair Gold 850W
Corsair H80
Corsair 600T Graphite
Old November 22, 2011, 09:00 AM
Bond007's Avatar
What will you be using this computer for? IMO go through NCIX on a nice2500k/2600k build unless you need the extra cores. That said if you have to pick one of those builds it would be x79 hands down. Also agree with dropping the velociraptor.
Old November 22, 2011, 11:56 AM
I wanted to buy it there for a reason of insurance.. long story short. I bought a build in march last year from them and received it and everything. But one day i came back home and some one broke in my house and stold a lot of my stuff including my PC. So my biggest fear is that if i buy from NCIX they wont pay back completely... Maybe someone can answer me on that question as well. I live in Canada, Quebec if anyone wants to know.
But for sure i will go check to buy it on NCIX... And ill call my insurance company and ask them if it matters where i buy it.
Thank you for your help people but i am still needing some help!
So just to be clear, should i go with the asus rampage extreme 4 or the p9x79 deluxe?
Old November 22, 2011, 12:18 PM
I havn't read all post because im in a bit of a hurry. I may be wrong but i believe that RAM does not clear for the NOCTUA NH-D14. Then again, i could be wrong.
Old November 22, 2011, 12:39 PM
I find it hard to build a pc on NCIX, can someone please build me a build with at least gtx590, asus rampage 4 extrem, 16 ram 4go x 4, liquid cooled, bluray writer/reader.
It would be greatly appreciated!
Thank you!
Old November 22, 2011, 12:40 PM
You need to talk to your insurance company. But my past experience has been that they don't care, they just want a quote from *whoever* on the replacement, then will approve the purchase, assuming it's in line with your policy's payout.
2600K @4.6
P8Z68-V Pro Gen3
Gigabyte GTX780
Corsair Gold 850W
Corsair H80
Old November 22, 2011, 02:00 PM
Alright, can you help me build a PC on the NCIX website and send me the link? That would be greatly apreciated!
Old November 22, 2011, 02:02 PM
Eldonko's Avatar
Hardware Canucks Reviewer
For the same amount of $$ you should definitely be going with X79. There is no reason to build a prev gen machine whatsoever.
  #19 (permalink)
Old November 22, 2011, 02:53 PM
No, I'm at least as lazy as you are if not lazier.
2600K @4.6
P8Z68-V Pro Gen3
Gigabyte GTX780
Corsair Gold 850W
Corsair H80
  #20 (permalink)
Old November 22, 2011, 03:01 PM
dandelioneater's Avatar
Originally Posted by Arinoth View Post
Is there any reason why you are buying from them. You are aware you could buy parts for a system at NCIX, price match them to whoever has them on sale the cheapest, then for only 50$ have NCIX build and test it for you (the hardware, even Win 7 if you bought that from them too)
I would seriously consider buying the parts from NCIX, and having them build it for you. I had a friend buy a pc from ibuypower last year, and he got a bad memory stick. Took alot of time and effort to get them to send him a replacement. The cable management was non existent, he got a UD2 board, and sub par psu. With NCIX you will be able to get proper components and you know it will be built well.
*When are you looking to buy this? PM me and I can select the parts you want and price match them then send ya the link. Wouldn't you like to try build a beast of a system like this yourself?
Tags
asus , help with new build , new build , x58 , x79
Building Again fyshawk New Builds 0 May 9, 2010 06:00 PM
Building an HTPC - Critique my build! Andy New Builds 16 September 9, 2009 07:40 AM
Building right now... need a little help somecanadianguy New Builds 44 April 4, 2009 05:36 PM
Building New Rig swiftk1 New Builds 7 August 27, 2008 02:16 PM
Building another rig! Kassela Troubleshooting 5 March 17, 2008 10:14 AM
