Help a noob out!
1. What YOUR PC will be used for. Gaming
2. What YOUR budget is. 500 (soft cap)
3. What country YOU will be buying YOUR parts from. Canada
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture. Prefer brands with best RMA.
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are. I need to buy new CPU, mobo first, then after that probably PSU and videocards.
6. IF YOU have searched and/or read similar threads. A lot.
7. IF YOU plan on overclocking or run the system at default speeds. I need help deciding this
8. WHEN do you plan to build it? Probably Christmas, boxing day? :D
9. What resolution do you use? 19x10
Hi,
Finally exams are coming and will be over soon, I'm planning to buy myself a new computer, for gaming mostly.
My budget is around 500, but I guess I can over if needed. (less is fine too :D). This seems a bit long, and from all of the other exactly the same threads, you guys must be tired. I would too. But please take a read and help me out.
Here are my questions:
1. I looked at the Anand bench for the 2100 and 2500k, the difference in performance do now impress me at all. I mean for almost another $100, I might be getting a few more frames. So the question is, would an OC 2500k, lets say, at 4Ghz ( I want to be a bit conservative here) increase its performance much? I understand that 2500k is more future proof and is just better at multitasking, but I'm only interesting in gaming performance for now. Really, would the extra $100 be worth it?
2. That leads to the second question of mine. I understand that by getting 2100, I don't need an expensive mobo since I wont be ocing, but would be otherwise if I get the 2500k. From what I read so far, the main difference apart from more features that expensive boards give, is the phases.
If I'm going for the 2500k, can I get the MSI Z68A-G45? It has SLI which I want (I've heard Crossfire is not good), MSI also has good RMA process in Canada too as I read in another thread here. The price is pretty cheap. The downside probably is the number of phases, it has 6, but I've read reviews on Newegg and it seems like ppl can get 4.5GHz with this board. That to me is good enough, or even 4.3Ghz.
I think there are some cheap Gigabyte boards as well, but their RMA process, from what I read here, is not so good in Canada, so I want to avoid that.
Basically, I want the best performance/price hardwares ( I will be willing to go as high as needed though, provided it is good upgrade) since money is still an issue, especially with international tuition being sooo high. The budget right now is for the CPU and mobo only, I will upgrade my PSU and video card later. That doesn't mean I have the whole 500 to spend on CPU and board only though.
That's about it, any input is greatly appreciated. I hope you understand most of what I said, as I am still ESL. I have come to love this forum so much, its the first in my Chrome list :D.
P/S: To the mod or admin:
Do you think it would be a good idea to have a sticky thread that details what is the best hardware selection for each criteria? Can be price, performance ratio, RMA...etc. I spend the majority of times here to search for these, and while I do enjoy reading them, it was tedious to search. I'm not trying to be lazy or promote laziness, but I think it would help noobs like me out so much, and will draw much more traffic to HWC.
E4500, 2GB DDR2-800, Coolermaster 500W PSU.
