Old November 15, 2011, 06:42 AM
Default TV as monitor
hi im buying a powercolor 6950 2GB and i was wondering would i only need a hdmi cable to use my tv as a monitor???
hope you guys and girls can help,
thanks.
Old November 15, 2011, 07:22 AM
supaflyx3's Avatar
as long as the card you're buying has an HDMI port, or a dvi-hdmi adapter, then yes that's all you need.
Old November 15, 2011, 08:55 AM
bissa's Avatar
as long as you can interface with it, you can.
but TVs are not designed for use with a computer. reading text is a pain on TVs. but if you are going to use it as a secondary monitor for movies/gaming then it would fill its need nicely.
Old November 15, 2011, 09:59 AM
im using it for gaming... skyrim and battlefield 3 mostly.
thanks for your reply.
Old November 15, 2011, 10:57 PM
The brightness if you sit up close, is going to kill your eyes.
Old November 16, 2011, 12:57 AM
say what? No issue there, 5+ years on large displays, 50" or more, from 10' away : no issues whatsoever. Just one tip : don't max the resolution , I was keeping it 1280x720 in order to make the icons and text easier to read, but with Firefox once you hit Ctrl+ a few times text will enlarge at acceptable levels.
Old November 16, 2011, 06:33 AM
Say what? I'm using a tv as a monitor and the text is no different than using a actual pc monitor. Welcome to 1080p monitors.
Uh... that is just ludacris.
Old November 16, 2011, 07:08 PM
In what way? Large LCD TVs are meant to be viewed at a distance and their range for brightness is limited.
Hey, whatever works for you!
Old November 16, 2011, 08:41 PM
I'm sitting about 6' from my tv and it causes me no issues whatsoever.
Sitting 2' from a 46" tv is just being dumb.
Everyone knows that if you go bigger you need to sit further back.
Old November 16, 2011, 09:27 PM
bissa's Avatar
oh, what I've seen is that they are pretty terrible for use as a monitor. they use a couple of them as a secondary monitor at my school. it's about 50 inch, 1080P, and I'm viewing it from about 10-15 feet and it's still noticeable that it's a little fuzzier. might be the settings used, or the make/model.
My new monitor... Toronto122 Case Mods, Worklog & Gallery 28 August 23, 2009 02:12 PM
New monitor Evylldemon Display Units 0 July 18, 2009 05:38 PM
[WTB] 22'' to 24'' LCD monitor Jacka Buy/Sell & Trade 1 January 27, 2009 04:46 PM
No 2nd monitor Phobia Troubleshooting 17 August 16, 2008 07:41 AM
Hd + Monitor Help derrXIII Display Units 3 July 28, 2008 03:33 AM
