Old October 31, 2011, 11:19 PM
Default optimus haf
- my pc will be used for a far bit of gaming such as crysis warhead, 1 and 2 far cry 2, bf3, mw3, medal of honour, and more and school work.
- $1200 including shipping
- australia www.pccasegear.com
4. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
- i intend to use my micro atx motherboared from asrock it supports the x6 procesors just not sata 3 or ddr3 but will upgrade in the future just trying to save money atm.
5. WHEN do you plan to build it?
when i gather the money to build it.
6. What resolution do you use?
1920 x 1080 or 1920 x 1200
the parts i have been looking at include:
amd x6 1090t
coolermaster haf x
coolermaster silent pro m700w
4 gigs of ddr2 800 ugrade with new MB down the track.
msi gtx 560 to twin frozr ll OC
24 inch benq lcd moniter.
1 tb WD black
im using a old micro atx i have that support the x6 cpu i was wondering if the hyper 212+ will work on a micro atx boared if not wat works well on micro atx motherboareds.
this will cost: $1200 deliverd
what setting will i be able to play new games on ?
thanks,
steven
optimus haff! build tell me your opinion. mrperfect1995 New Builds 1 November 4, 2011 09:35 AM
Optimus Woes... CMetaphor Mobile Computing 3 October 13, 2011 12:28 PM
LG Optimus One Android Phone (TELUS) jcmaz Price Check 11 August 13, 2011 12:42 PM
LG Intros Optimus Pad Tablet FiXT Press Releases & Tech News 30 February 17, 2011 08:39 AM
MSI GT663 Launched. No Optimus? geokilla Mobile Computing 0 October 1, 2010 10:00 PM
