Originally Posted by jef.paas three guys at the PC stores said the Cooler Master 1000w silent pro could handle the gtx 590 x 2 for SLI. |
You won't find much love for CM PSU's around here. They're one of the manufacturers that typically take a good platform and butcher it into a POS to cut costs. The Silent Pro Hybrid units they just released seem to be a big step in the right direction though. I would consider getting a lower wattage, higher quality unit.
I would get a single 590 and forget about SLI, the scaling isn't good enough to justify the extra ~$750. You'll be much better off selling the 590 and buying the latest gen when new cards come out in the coming months. The 590 will retain its resale value much better than dual 580's will as well and performance will be almost the same.
The 2600k might not be a bad idea since you're building the rig around BF3. It *should* be able to make use of the extra threads - but I would wait for some benchmarks to see how well BF3 takes advantage of the extra threads.
