I'll be heading into building my own desktop this time around as opposed to a prebuilt, and I basically need advice and opinions on how the build(s) look so far and what parts I should be using. I'll be using the pc mainly for gaming @ 1680x1050 resolutions, maxed settings at potentially 4xAA and 8xAF. I'll be using the build to run BF3 and the like. I have some of the major components selected so far, although I'm still at odds over which parts to select in some cases.
Current Setup: LITE-ON DVD Burner COOLER MASTER HAF 912 CORSAIR Builder Series CX600 V2 G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM ZOTAC ZT-50301-10M GeForce GTX 560 Ti (Fermi) ASRock Z68 Extreme3 Gen3 LGA 1155 Intel Z68 Intel Core i5-2500 Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) Parts I'm fairly certain of:
Cooler Master Case (from what someone told me it cools very well)
Samsung Spinpoint F3 (many people recommend these hard drives, and the price is great for its capabilities)
ZOTAC 560 Ti (was going to go with a Twin Frozr II OC until I heard of the issues people were having on them; some were on their 3rd or 4th RMA, and the NVIDIA support forums are flooded with artifacting issues with factory OC'd cards. ZOTAC is apparantly a sister company to SAPPHIRE, a highly regarded ATI brand, and EVGA didn't sell any reference-clocked 1GB versions on NewEgg)
Intel core i5-2500 (same as above; decided against overclocking and therefore downgraded to the standard version)
Parts I'm unsure of:
LITE-ON DVD Burner (I honestly don't know which DVD burner I should purchase. Was debating about purchasing an LG but they apparantly have speed issues, while many people seem to always go with LITE-ON in their builds)
Corsair CX600 (Mixed bag of opinions from people; some suggest the Antec Earthwatts 650, others suggest this one, others suggest the TX650 from Corsair since it's higher quality. What I have the most concern with is the high pitch noise some people are commenting about with their CX600's)
Ripjaws RAM (certain of brand name and size, though a little confused as to what speed to get (1333MHZ, 1600MHZ, and the like))
ASRock Extreme3 Gen3 (wasn't really sure whether to mark this as certain of or not; one person commented that he always went with ASRock motherboards, while others suggest GIGABYTE and ASUS)
That's basically where I'm at so far. My current setup was largely inspired by TweakGuides' "Hardware Confusion 2009" guide, where he expressed his reasons against overclocking and some of the parts he selected in his build. Ultimately I'm sortof along the same line as he is; wanting a system that will work from the moment its powered on and have almost no issues, and can withstand years of use.
Thanks for the responses :)
