My next Desktop - Input Required
Hey, need some direction. Upgading from an Aopen MiniPC (MODT)....need some advise for the next build.
I have a 12 TB win 2008 r2 server that has all my media, etc.
Would like to build a SFF PC that I can do some basic stuff with. Thanks for stopping by.
Web, edits for family pics and vids, everyday stuff. no gaming, no overclocking, etc
700-750 CAD shipped
Canada
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
Intel SB please
all new please
anandtech, here, hardforum....
no o/c - pure stock
would like to order in 3-4days
9. What resolution do you use?
have 1 20" Dell widescreen running 1920x1080, may upgrade to 24" at same rez near x-mas
_____________________________
Here is what I am thinking:
__________________________________________________ __________ _____________
Intel Core i3 2125 Dual Core Hyperthreading Processor 3.3GHZ LGA1155 3MB Cache 65W Retail Box
$163.62 $163.62
ASUS P8H61-I Rev 3.0 MINI-ITX H61 LGA1155 DDR3 PCI-E16 SATA2 USB3.0 HDMI DVI VGA Audio Motherboard
$83.08 $83.08
Kingston HyperX KHX1600C9D3K2/8GX 8GB 2X4GB DDR3-1600 XMP Dual Channel Memory Kit
$56.49
Lian Li PC-Q11B Aluminum Mini Computer Case Mini ITX 1X5.25 2X3.5 INT 2X2.5 INT USB 3.0 - Black
$80.16 $80.16
Silverstone Sfx Series ST45SF 450W Power Supply Small Form Factor 24PIN PCI-E 36A 80+ Bronze Black
$79.99 $79.99
64GB m4 SSD 2.5 SATA
$120.88 $120.88
Western Digital WD Scorpio Black 500GB 2.5IN SATA2 7200RPM 16MB Notebook Hard Drive
$64.99 $129.99
YOUR TOTAL $706.21
Thoughts on the SFX PSU?
Is there a modular ATX PSU with short cables?
Also, would like to raid 0 the 2-2.5" WD Blacks for my scratch HDD set - thoughts, better to go to 3.5" hdds or just use a 1 or 2TB 3.5" drive?
