Old September 30, 2011, 03:09 PM
Default $450 left to spend on Proc, Videocard, Mobo, and Disc Drive
I already have the following parts:
Coolermaster HAF 912
OCZ Fatal1ty 550W Power Supply
Patriot G series ‘Sector 5’ Edition 8GB
And I have 3 old 250gb Hard Drives that I'll be Raiding
I still need to get a mobo, disc drive, proc, and video card for $450 . This build will be used mostly for gaming, if you needed to know.
What I'm thinking:
Amd X4 955 BE $105
XFX HD 6950 $190 on sale
Lite-On Dvd Drive $20
Asus EVO 990x Mobo $135
This is $450 exactly. I plan on using the 955 for a while, at least until December, when I can afford the Bulldozer. Any suggestions? Remember, primarily a gaming build.
Old September 30, 2011, 04:02 PM
CMetaphor's Avatar
Quadfather
Seems like good options to me considering the budget!
Just make sure that the motherboard will or already has a bios upgrade to support Bullsozer processors and you're set!
.... And don't forget to grab a heatsink when you can afford one and OC the processor! Will help a good deal in gaming especially.
Old September 30, 2011, 05:14 PM
NI3 NI3 is offline
Where is this $190 6950? I would be on that in a heart beat.
As for the build, it is pretty good. I might say drop the 8GB and get a 212+, then another 4GB when you upgrade to bulldozer. I am thinking that you would see better performance with a higher clock speed, than with 8GB over 4GB. Playing at 1920x1080, I do not break 4GB usage when gaming. It would be wise to not wait too long to get that extra 4GB stick though, as RAM prices may start rising again. Just my thought...
Old September 30, 2011, 05:28 PM
Silvgearx's Avatar
Hmm, how is that psu, since most amd chips are pretty power hungry.
That system might pull 400W at full load, might be a bit much on a OCZ Fatality psu.
Other wise the match up looks good.
Old September 30, 2011, 06:20 PM
techman95's Avatar
power hungry? i run a 1090T at 4Ghz, 8gbs of ram, 2 hdds, a 6870 w/ 1Ghz on the core and 1200 on memory, and i pull maybe 350w from the wall so a 955 will be even less, he'll be fine for now but an 8 core bulldozer might be different
Old September 30, 2011, 08:00 PM
Thank you all for your quick response! I already own the power supply and ram, so I have no choice there. Thank you all so much for your help, I'll be ordering this tomorrow more likely then not. My only question that remains is as follows:
What's the chance that that memory will have incompatibility with that mobo?
Old September 30, 2011, 08:14 PM
techman95's Avatar
almost none,and since the asus boards have mem ok (im pretty sure yours does) even if you do you just hit the button and it solve it.
Old September 30, 2011, 08:18 PM
Also, Newegg.com - 3-DAY DEALS! $329.99 Lenovo 3GB Laptop, $139.99 ASUS 23" LCD Monitor... for those who were wondering.
Old October 1, 2011, 06:53 AM
Bond007's Avatar
given the budget and the planned upgrade path I would say those are pretty solid choices. I Agree that its not the best PSU choice out there, but it should run the rig fine (would have picked a different one myself).
Old October 1, 2011, 11:16 AM
I ordered the rest of the parts today! Thank you all for your help!
Price Check: SSD drive, Motherboard, Ram & videocard terrybear Price Check 0 September 4, 2011 04:13 PM
What amount should I spend on a MOBO? Yeno CPU's and Motherboards 12 June 23, 2011 06:37 PM
[WTB] Wanted: P35 Mobo, and Cheap 775 Proc arekieh Buy/Sell & Trade 3 April 14, 2009 06:53 PM
[WTB] Wanted: 775 Proc arekieh Buy/Sell & Trade 4 April 14, 2009 06:52 PM
WD Dual Proc HDD's encorp Storage 42 July 19, 2008 09:11 AM
