Old September 19, 2011, 03:47 PM
Default Opinions: $1100 build. Worth it?
So this is my first time choosing computer parts instead of going to FutureShop and buying something that is all bloated and isnt exactly what I want. Im just doing it from the Ncix website.
No brand real brand preference, no re-usable parts, no over-clocking. I am located in Canada and buying parts in Canada, Coquitlam area
Do all these parts work together?
Is the power supply sufficient?
Is there anything that I could get to replace something and save a bit of money?
I just want a computer that will be fast, and also play my Sims 3 game with all gameplay settings on High.
So it would be much appreciated if you guys could give me your input.
Also, for a cd/dvd drive...what is a good basic one for just burning cds and maybe playing movies?
$1247.10
UPDATE! Processor : Intel Core i5 2400 Quad Core Processor LGA1155 3.1GHZ Sandy Bridge 6MB ($194)
UPDATE! Motherboard : ASUS P8P67-M Pro REV3.0 mATX P67 LGA1155 DDR3 2PCI-E16 1PCI-E1 USB3.0 Sandy Bridge B3... ($135)
UPDATE! Ram : Mushkin Enhanced Silverline Stiletto 4GB 2X2GB PC3-10666 DDR3-1333 9-9-9-24 Dual Chan... ($26)
UPDATE! Video card : Gigabyte GeForce GTX 550 Ti 970MHZ 1GB 4.2GHZ GDDR5 Dual DVI Mini-HDMI DX11 PCI-E Vid... ($124.99)
Computer Case : Compucase 6C28B ATX Case Black 4X5.25 2X3.5 4X.3.5INT W/ Front USB & Audio No PSU ($34) *
UPDATE! Power Supply :
XFX 550W PRO550W Core Edition Single Rail ATX 12V 44A 24PIN ATX Power Supply 80PLUS B... ($49.99)
Monitor : Samsung S20A300B 20IN Widescreen LED LCD Monitor Black 1600X900 5ms 1000:1 DVI VGA ($140)
Operating System : Microsoft Windows 7 Home Premium Edition 64BIT DVD OEM ($116) *
Accounting & Office : Microsoft Office 2010 Home and Student English 32/64BIT Medialess Product Key Card No... ($120)
Hard Drive : Seagate Barracuda ST31000524AS 7200.12 1TB SATA 32MB Cache 3.5IN Internal Hard Drive ... ($60)
Keyboard : Logitech K750 Wireless Cordless Solar Powered Low Profile Thin Keyboard ($75)
Mouse : Logitech M505 Wireless Cordless Ergonomic Laser Mouse - 3 Year Battery - Black ($60)
Do you think that this Custom PC build will run better, the same, or worse as this IMac??
Are the 2 graphics cards extremely different for playing Sims 3 on highest gameplay settings?
Processor 3.6GHz Intel Core i5 processor
Cache 4MB fully shared L3 cache
Memory 4GB (two 2GB SO-DIMMs) of 1333MHz DDR3 SDRAM; supports up to 16GB
Hard drive 1TB Serial ATA1; 7200 rpm
Optical drive Slot-loading 8x SuperDrive with 4x double-layer burning (DVD±R DL/DVD±RW/CD-RW)
Display 21.5-inch (viewable) LED-backlit glossy 16:9 widescreen TFT active-matrix display; 1920 by 1080 pixels; millions of colors; IPS technology
Video Built-in iSight camera; Mini DisplayPort output with support for DVI, dual-link DVI, and VGA video (requires adapters, sold separately)
Graphics ATI Radeon HD 5670 with 512MB of GDDR3 memory
FireWire One FireWire 800 port; 7 watts
USB Four USB 2.0 ports
SD Card SDXC card slot
Audio Built-in stereo speakers with two internal 17-watt high-efficiency amplifiers, built-in microphone, optical digital audio output/headphone out, optical digital audio input/audio line in
Ethernet Built-in 10/100/1000BASE-T (Gigabit)
Wireless Built-in AirPort Extreme 802.11n Wi-Fi wireless networking2 ; built-in Bluetooth 2.1 + EDR (Enhanced Data Rate)
Included accessories Apple Wireless Keyboard and Magic Mouse
Other Built-in IR receiver
Size and weight Height: 17.75 inches (45.1 cm)
Width: 20.8 inches (52.8 cm)
Depth: 7.42 inches (18.85 cm)
Weight: 20.5 pounds (9.3 kg) 3
Old September 19, 2011, 03:49 PM
ultraman7k's Avatar
you will want to find a different motherboard as the one you selected is an AMD socket.
You will want one that is LGA1155 compatible, or you may decide to the AMD processor route?
Old September 19, 2011, 03:56 PM
Would this work? Is it good?
ASUS P8P67-M Pro REV3.0 mATX P67 LGA1155 DDR3 2PCI-E16 1PCI-E1 USB3.0 Sandy Bridge B3 Motherboard
stoanee's Avatar
To start with you have picked out an Intel processor and an AMD mobo. They are not compatible.
Personally I would go with a different case, maybe something like this:
\NCIX.com - Buy Coolermaster Elite 370 Black Mid Tower ATX Case 3X5.25 1X3.5 5X3.5INT No PS - COOLERMASTER - RC-370-KKN1 - in Canada
heatware
Old September 19, 2011, 03:59 PM
Or would this be better?
Intel BOXDH61CRB3 mATX H61 LGA1155 DDR3 Sandy Bridge B3 Motherboard
N thank u for the input
Old September 19, 2011, 04:32 PM
techman95's Avatar
no that p67 one is better. but on this budget i would suggest going amd, for us less financially savy gamers they bring alot to the table specifically the six cores. i just picked one up to replace my first phenom and i love it. plus you can get more out of it than that budget i5 that cant be over clocked or any thing. and another note is find a different psu cooler master psus are a no go ever.
Old September 19, 2011, 04:34 PM
Unless you really like the idea of nice keyboards, I would save the cash and get a cheap keyboard and mouse. I personally have an under $20 mouse and under $20 keyboard. They work fine, for all I do. (Surfing, Starcraft II single player or vs. AI, single player FPS)
Asus is a good name for mobos, so long as your mobo supports your CPU it's all good.
It may also be worth upgrading the power supply. Unlike other components, a bad PSU can take other components with it if it fails, so a PSU is a terrible thing to cheap out on. A first guess at quality is to look for an 80+ rating, (or 80+ Bronze, Silver or even Gold). I think 550W would be fine for your build. I have an i5 2500K and 6870 (next step up or maybe on level with the 550) and a 600W PSU with no issues.
ex (the PSU I have):
NCIX.com - Buy Corsair Gaming Series CMPSU-600G 600W ATX Power Supply Active PFC 140MM Fan *3 Year Wrty* - Corsair - CMPSU-600G - in Canada
Old September 19, 2011, 04:37 PM
PerryC's Avatar
Use Shoptbot or another pricing comparison site to get the best price you can, then price match everything at NCIX.
Buy Intel [BX80623I52300] Intel Core i5 2300 Quad Core Processor LGA1155 2.8GHZ Sandy Bridge 6MB $179.09 until 16 Oct
ASUS P8H67-M PRO/CSM REV3.0 H67 mATX LGA1155 2PCI-E16 2PCI HDMI DVI Sandy Bridge B3 Motherboard - DirectCanada $109.69, not a P67 board, but will be fine for what you are looking for.
NCIX.com - Buy Kingston ValueRAM KVR1333D3N9K2/4G PC3-10666 4GB 2X2GB DDR3-1333 CL9 240PIN DIMM Memory Kit - Kingston - KVR1333D3N9K2/4G - in Canada $25.98, its a dual channel board, run two sticks of ram
ASUS GeForce GTX 550 Ti 910MHZ 1GB 4.1GHZ GDDR5 DVI HDMI VGA PCI-E Video Card - DirectCanada $128.32, but there are folks on these forums that will tell you the 550 cards aren't the greatest.
Coolermaster Elite 370 Black Mid Tower ATX Case 3X5.25 1X3.5 5X3.5INT No PS - DirectCanada $39.40, the same case Stoanee linked, but better quality than the one you had looked at.
NCIX.com - Buy Corsair Builder Series CMPSU-600CXV2 600W ATX Power Supply Active PFC 120MM Fan *3 Year Wrty* - Corsair - CMPSU-600CXV2 - in Canada on sale for $54.99 for a couple more days at NCIX.
Seagate Barracuda ST31000524AS 7200.12 1TB SATA 32MB Cache 3.5IN Internal Hard Drive OEM - DirectCanada $49.69, lots of storage room for you.
NCIX.com - Buy Samsung S20A300B 20IN Widescreen LED LCD Monitor Black 1600X900 5ms 1000:1 DVI VGA - Samsung - LS20A300BSY/ZA - in Canada on sale for $114.99 for another couple of days.
Buy MICROSOFT [GFC-00599] Microsoft Windows 7 Home Premium Edition 64BIT DVD OEM $93.79 until 18 Oct
NCIX.com - Buy Microsoft Office 2010 Home and Student English 32/64BIT Medialess Product Key Card No DVD - Microsoft - 79G-02020 - in Canada $114.99 for a couple more days
Logitech K750 Wireless Cordless Solar Powered Low Profile Thin Keyboard - DirectCanada $73.34, not much of as difference but every bit helps.
Logitech M505 Wireless Cordless Ergonomic Laser Mouse - 3 Year Battery - Black - DirectCanada $42.30
Total 1026.57 no taxes or shipping
edit-- as has been suggested you could probably price a similair build for AMD and get slightly better performance. The mobo I suggested above was picked solely for the "budget" side of the house.
The oath to serve your country did not include a contract for normal luxury, and comforts enjoyed within our society. On the contrary it implies hardships, loyalty and devotion to duty, regardless of rank
Old September 19, 2011, 04:48 PM
I know you said its your first time doing this, but I would change most of the parts you selected. motherboard has to be changed (incompatible), faster processor for less, would get better RAM (its cheap now), video card is expensive for a 550, case and power supply aren't very good, ....
Anyway, this is all my opinion, but a real quick look through NCIX weekly sale I picked these without indepth research.
Case (HAF 912)
RAM (Mushkin silverline 2x4gb)
Windows 7 (on sale in weekly sales)
CPU (i5 2400)
GPU (gigabyte geforce 550)
PSU (xfx pro 550w)
Motherboard (gigbyte z58 )
Monitor (samsung 23inch HD monitor)
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old September 19, 2011, 05:24 PM
Thank you all so much
$1100 gaming pc build help and opinions Sharp-Shooter New Builds 20 March 29, 2011 04:11 PM
Build for little brother ~ $1100 after tax Jake_HT New Builds 6 August 28, 2010 06:54 AM
Need your opinions on this WC-Build Closed Note Water Cooling 3 August 13, 2010 02:14 AM
Build Opinions icecoals New Builds 45 May 6, 2010 04:12 PM
New Build need opinions FrankyG New Builds 11 September 22, 2008 10:00 AM
