Old August 31, 2011, 04:17 AM
Default Memory and Cooler for 2600K
so, for my build, I'm going to be using a SG07 with a 2600K cpu. I was just wondering if my memory is a good choice(i honestly just picked one of the more expensive sets) and if my cooler would work with my case(i picked the block cause it looked cool...)
memory: Mushkin Enhanced Redline 1600Mhz CL-8 8GB @ $108.99
cpu block: Prolimatech Samuel 17 @ $42.20
I'll be doing mainly programming and some very moderate gaming on the machine(when i can afford a gpu lol).
I'm thinking of going fanless on the cpu block and just having the giant case fan do the work of moving air. thoughts?
I was also kinda wondering how much overclocking I could get away with in such a small case. As well, I would like to upgrade to a 27" 1440p display at some point and I would need some power budget reserved for the gpu. Meaning that I should consider not overclocking the cpu at all and just getting the 2600.
Old August 31, 2011, 05:30 AM
krazyups's Avatar
I'd probably go with a Corsair H60 if you can get catch one on sale (easier now since it's been out for a while), as it will drastically outperform the Samuel 17 for ~$15 more (). As for the RAM, that set might be a little overkill for your purposes, you will be just fine with a less expensive set, something with CL-9 timings, since you're not going for that killer overclock.
As for overclocking, you should easily be able to hit ~4.4 -4.6GHz with that chip and an H60, if you were to stick with the Samuel 17, you're probably looking at 4.1 - 4.2GHz, depending on the chip of course.
Don't worry about the power, your video card will use predominantly the 12V rail, so you should have no issues there.
Folding with rig under My System Specs, GTX460 in the kids' computer and whatever my dad can contribute.
Old August 31, 2011, 06:54 AM
ya memory doesn't matter that much
review after review shows that...
so ya 9-9-9-24 timings will be fine and about half the price
Old August 31, 2011, 07:09 AM
and an h60 won't work in that case
no place to mount the rad and fan...
Old August 31, 2011, 07:16 AM
just be careful with the case
Sugo SG07 Building A PC | bit-tech.net
they had a problem with a flat cpu cooler and adding a video card
they say how long the cpu cooler can be
Old August 31, 2011, 07:25 AM
i'm also concerned about that cooler
doesn't seem to perform that well. even with a fan on it...at high speed
Prolimatech Samuel 17 - Test: Temp Results
this is low speed results
Prolimatech Samuel 17 Small Form Factor CPU Cooler Review
now i know you're using a lower Thermal design cpu, so i dunno...
Old August 31, 2011, 08:35 AM
Eldonko's Avatar
Hardware Canucks Reviewer
No way I would spend $100 on memory, there is no point. Plus that kit is out of stock anyway.
I would go with this: Newegg.ca - G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
Or if you want to spend a bit more this: Newegg.ca - CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 15000) Desktop Memory Model CMZ8GX3M2A1866C9R
Old August 31, 2011, 08:40 AM
if you want fanless,you'll need the hr-02, the original one. :)
and as for ram, as long as its 1.5v and not too high of a profile,you'll be fine.
P8P67 Deluxe and 2600K cooler? snowbound CPU's and Motherboards 7 March 29, 2011 08:55 AM
Ram memory cooler martin_metal_88 Air Cooling 7 June 17, 2009 09:10 PM
[WTB] OCZ XTC Memory cooler =) Realityshift Buy/Sell & Trade 6 April 21, 2009 03:36 PM
powering xtc memory cooler MurdaZ Power Supplies 7 February 17, 2009 12:58 PM
How to make you own Memory Cooler (RAM) Boldeagle Guides & How-to's 24 July 31, 2008 11:32 PM
