well,what do you like? asus? giga? msi? first and last have rma faciities in toronto. giga is in the states last i checkered.
you can go anywhere from 100-200 dollars for the mobo,depending on what features you need and what kind of overclocks,if any,
you would like. the asus pro is popular. ud3/4 from giga as well. try to score in the z68 chipset family.
the only thing which might not be the clearest answer right now,aside from the cpu with your multithreaded apps(hint bulldozer 8 cores)
, is the gpu. since new stuff is about to hit.
or so they always say :p
