-   -   Not new Upgrading and need help (http://www.hardwarecanucks.com/forum/new-builds/45982-not-new-upgrading-need-help.html)
Kartoon87 August 28, 2011 07:56 PM
my mobo is Board: ACER G33T-AM 1.0 oem DARN!!!
Ok i think i got everything. So what i want to do is upgrade my ram and gpu and to windows 7 for the 64 with 8gbs of ram. i was then thinking i can turn paging off to take a load off the cpu but i cannot OC THIS BOARD and im near broke and i want to play battlefield 3 on full settings if someone can help me out and get me to that point spending as little money as possible that would be great
Cheers -Craig
2.40 gigahertz Intel Core2 Quad
64 kilobyte primary memory cache
4096 kilobyte secondary memory cache
64-bit ready
Multi-core (4 total)
Not hyper-threaded
DDR2 PC2-8500, DDR2 PC2-5300, DDR2 PC2-6400
Memory Type: DDR2 PC2-8500, DDR2 PC2-5300, DDR2 PC2-6400, DDR2 (non-ECC)
Maximum Memory: 8GB I HAVE 3
Slots: 4
Each memory slot can hold DDR2 PC2-8500, DDR2 PC2-5300, DDR2 PC2-6400 with a maximum of 2GB per slot.*
NVIDIA GeForce GTX 260 [Display adapter]
Samsung SMBX2450L [Monitor] (23.4"vis, s/n 1497773121, October 2010)
Rocketfish 5.1 PCI Sound Card
Hitachi HDT725050VLA380 [Hard drive] (500.11 GB) -- drive 0, s/n VFJ401R4D74GNK, rev V56OA73A, SMART Status: Healthy
Windows Vista Home Premium Service Pack 1 (build 6001)
Install Language: English (United States)
System Locale: English (Canada)
550w psu BFG
_dangtx_ August 28, 2011 08:00 PM
i wouldnt touch anything. oem boards, you dont mess with. that includes cpu upgrades
sell it and build one from scratch.
Kartoon87 August 28, 2011 08:02 PM
cant
no money so with what i just said i still need to move ahead with that idea
and i have no faith in my ability to build a computer at that
Andy August 28, 2011 08:26 PM
Yah ... you're simply not going to be able to do what you want to with those parts. Nor are they worth upgrading. I would just start saving for a new build.
_dangtx_ August 28, 2011 08:31 PM
ok maybe teh ram,and then you'll need a 64 bit os but anything more than that? forget about it.
or sell the lot as we speak and the nsave the moneys for the upgrade. an i3 sandy bridge or 1156 clocked high
will do marvels. i'd still go with a 2500k build. you can probably sell it with the lcd for like 3-400 i think
Kartoon87 August 28, 2011 08:42 PM
i think i might die ... is there really no way ... what about 560 nvidia or like a card with 2gbs of ram will that take a load off my cpu
last last resort i buy a new case and mobo and have a shop install it and then i can oc my cpu
what will that do me
Kartoon87 August 28, 2011 08:46 PM
sell it with the led* and this screen is brand new why would i sell it
2ms response time 23inch widescreen is that not good?
PerryC August 28, 2011 08:48 PM
What they said. The only way to ge better performance out of the cpu is to go to a quad 9xxx series. They are eol'ed now, and stupid expensive resale used.
Memory can be done fairly cheaply ~$45-$50 for 2 x 2 GB sticks of PC2-6400.
Not really sure if its worth it though.
_dangtx_ August 28, 2011 08:50 PM
try not to :)
no. bottlenecked it shalt be. heavily.
i would run caseless if that meant i could get an upgrade
hell,i am running caseless lol,but for different reasons.
then keep it.
where you buying from? you got ncix and the like in toronto,canada computers..the lot.
Kartoon87 August 28, 2011 08:51 PM
Yes but if i go forward get a new case and mobo i can keep upgrading right?
like lets say i get a new cpu next then gpu
