<~----> Not new Upgrading and need help - Page 2 - Hardware Canucks
Old August 28, 2011, 08:54 PM
i live an hour north of toronto and what are you saying im going to be bottled on? my cpu to my gpu?
Old August 28, 2011, 09:05 PM
PerryC's Avatar
Not trying to discourage you here. You are facing the same situation I was/am still looking at. The biggest hurdle you are going to face is that the socket 775 stuff is 3 generations behind current technology, and in the next couple months will be down another generation.
560 series cards run in the neighbourhood of $180+ new. If you are going to get that decent a card, you should definitely look at newer board/cpu combo. You are going to have to go that route at some point, might as well start now.
The oath to serve your country did not include a contract for normal luxury, and comforts enjoyed within our society. On the contrary it implies hardships, loyalty and devotion to duty, regardless of rank
Old August 28, 2011, 09:07 PM
errrrrr......... bf3 is like here. I dont know what to do.
what about getting a ncix prebuilt comp is there anyway i can get it for under 700 and run max settings on battlefield 3
Old August 28, 2011, 09:08 PM
you will probably benefit more from a cpu+mobo upgrade than a gpu upgrade which will,yes,be bottlenecked heavily.
look up ncix specials for a 2500 build.
its like you have a 4 cyl truck and you need to haul 8k pounds,. sure you can buy and install an old v8 in there, but the cost vs
future of the rig wont be worth it.
edit :
2500k and mobo and 8 gigs should be around 350-400 depending on the mobo,ram.
50-70 for psu
around 200 for the card
and so on.
my lack of knowledge is killing me here and i need to take the cheapest route
Old August 28, 2011, 09:12 PM
i was looking at the mobos on ncix but i cant figure out what one would be cheap and have a lil push for upgrading
Old August 28, 2011, 09:13 PM
we talking 775 or 1155 here? and plz dont double post. edit the one post :)
Old August 28, 2011, 09:15 PM
PerryC's Avatar
Do you absolutely need an Intel based build? Why not look at an AMD Llano based build. Has DirectX 11 capable integrated graphics, so you could hold off on getting a video card for a bit.
Maybe something like this NCIX.com - Buy NCIX Bundle ASUS F1A75-M Pro mATX FM1 Motherboard & AMD A8-3850 APU Retail - AMD - A8-3850-F1A75-MPro - in Canada
Buidling your own isn't that difficult.
  #19 (permalink)
$775?? max im willing to spend is 700 800 will kill me but id do it
i mean if i really have to get a new computer im not going to cheap out on everything because its not like i can do this all the time or ever :P
amd could be a future for me. all im really looking for is like money to fps ratio i just want to play bf3 full on settings
  #20 (permalink)
Old August 28, 2011, 09:18 PM
PerryC's Avatar
Dan is talking about sockets there...not dollars.
The socket 775 is what you currently have.
The socket 1155 is the current Intel.
Upgrading... SKW New Builds 12 September 23, 2010 03:36 PM
Upgrading 275 to 460's sli? Patramix Video Cards 11 September 17, 2010 09:42 AM
Upgrading forever Upgrading nerty New Builds 6 May 8, 2010 11:28 PM
need help upgrading muffler New Builds 11 March 28, 2009 05:59 AM
Upgrading (at last) Mysteryous Video Cards 0 January 5, 2009 08:32 PM
