-   -   Advice on a folding machine (http://www.hardwarecanucks.com/forum/new-builds/45966-advice-folding-machine.html)
Jaydu August 28, 2011 07:26 AM
I have just recently thought of building a folding/downloading and I got a sweet deal on a Intel DX58so. but I would like to do this cheaply, so far what I have
Case: thermaltake spedo
mobo: intel dx58so
cpu: looks like a i7 920 for 150
gpus: not sure yet any ideas?
hard drive: 40g ssd agility2 already had it.
ram: this is where I am confused abit how much do I need because I was looking at kingston 3x4g t1 for 100, then I as a set of 3x2g from mushkin for 50 but i could get a used set of 3x1g for around 30 dollars
I have 300 dollars left in my budget and the chip has eating up alot of that unless I can get my hands on a cheaper chip that would do.
but My real question is what should I cheap out on ram or cpu or gpu?
chubaka August 28, 2011 07:47 AM
only started to fold end of last year but AFAIK, GPU folding is the only way to go if you want to get substantial PPD's per day without running 24/7. The other option is to get an intel 2600k for big WUs but thats out of the question considering you are sticking with 1156...
I would suggest a used gtx 460..
3.0charlie August 28, 2011 07:55 AM
It depends what you want to fold with, CPU or GPU? I'd find a used 950, and some GTX460s / GTX550s / GTX560s.
As for ram, 3x2Gb is more than enough.
chrisk August 28, 2011 08:16 AM
Yeah most energy efficient way of folding is the CPU, and more points if you can clock that i7 920 high enough (~4GHZ). Otherwise, you shoulod jump on one of the suggestions made by 3.0Charlie and fold mostly GPU, with some regular SMP folding.
Either way, good to see another folder!!!!
frontier204 August 28, 2011 08:25 AM
An overclocked Core i7 920 on its own is a fairly good folding chip. With $300 and that kind of rig I'd get 3x2GB cheap RAM and perhaps a GTX 560 Ti.
I'm not sure how well 3x1GB would do if you want to fold bigadv units, but if it's just regular SMP, 3GB would be fine.
I wouldn't recommend lower than a GTX 550 Ti for Folding because low-end GPUs will rob some CPU performance from you and will not be worth their power consumption. Note if you can net a really cheap GPU which consumes very little power (<10W), you could just get components to OC your CPU as high as it can go and not fold on the GPU. I kinda do that with my home server which has no graphics at all and is accessible through SSH only.
Jaydu August 28, 2011 09:59 AM
Thanks so much for your input and keep it coming, I will grab the 3x2g kit from muskin for 50 dollars I do have one GTX460 cyclone I could use. that now leaves me with 250 left for the cpu and one GTX460
I have never sli anything in my life so what I would think is a truly newbie question do the cards need to be the same brand and everything or will another GTX460 1g ddr5 card work in sli with my msi cyclone?
supaflyx3 August 28, 2011 10:02 AM
Don't SLI them, use them individually. And if you can OC them high enough, you can expected 11-13,000 PPD depending on the WU.
But to answer your sli question, any brand will work, but if you buy a lower clocked one, your current card will downclock it self to the other cards speeds if running in SLI, and vice versa.
Jaydu August 28, 2011 10:49 AM
so would I be better off in just using one gtx460 and getting a i7 950 or using two gtx460 but not in sli which means just don't bridge them I'm guessing.
_dangtx_ August 28, 2011 10:58 AM
the gpu client can take as much as 10-20 percent off the cpu.
http://img508.imageshack.us/img508/3...ngcpuusage.jpg
supaflyx3 August 28, 2011 12:01 PM
correct, and not enabling SLI in the drivers.
