Old August 22, 2011, 04:58 PM
Bohrman's Avatar
Question 800D WC advice
Hey guys, i have been bashing my head on the wall for a few months now whether not i want this case or that or do i want air cooling or water cooling etc etc
So for my own sanity I'll just stick to the Corsair 800D (my initial choice). I mean it was either this or something from the guys down at murder mod murderbox, but damn is their stuff expensive (i could wait for the cosmos 2?).... i could easily spend a grand just on the case!
But since i've never watercooled before i kinda find my self in a similar situation.. should i pick this pump? that res? see a pattern haha? aah to be indecisive . So Which setup do you guys think will work best, any help is deeply appreciated!
Here is what i've come up with so far (they seem pretty standard... and yeah i'm no good with paint):
Old August 22, 2011, 05:09 PM
aircooling.it works.
water cooling. it works,better (if you do your homework AND spend the dough). some day youll have an accident and post a thread about it.
Old August 22, 2011, 07:30 PM
SugarJ's Avatar
_dangtx_, the question wasn't air or watercooling, it was how to go about watercooling.
For the OP, it depends what CPU you are trying to cool. Sandybridge chips run cool, so if that's what you are using I'd be tempted to run the CPU on the 240 rad if you go with split loops. Personally, I'd go with a single D5 pump / single loop just because it keeps it cleaner looking inside the case. Any of the 3 loop configurations you show would work, though.
Old August 22, 2011, 07:39 PM
i know,. tried to save him a headache+work :)
i say the simplest way around, though one pump at each end wouldnt be too bad.
Old August 22, 2011, 08:31 PM
Bohrman's Avatar
Thx for the replies, definitely the single loop looks much tidier and probable cheaper too. But i did like the idea that i could combine the res and pump together in one package rather than finding a spot to place the pump by itself. Maybe i could get it to sit on the divider between the psu and the motherboard under the gpus
Would this be a good D5? =Swiftech MCP655-B 12v Water Pump w/ 3/8" Conversion Kit (317 GPH) - FrozenCPU.com
As for the cpu i've been waiting on the bulldozer to come out but on the rare chance the reviewers here at HWC find it's junk i'll be grabbing a sandy bridge. It is supposed to be a 95watter like the sandy bridge so i would presume it'll run just as cool?
Old August 22, 2011, 09:06 PM
those 655's are beasts. from personal experience, the ones where you cant control the speed of it tend to outlive their controlled brethren..
could be because ppl play with it too much.maybe
sandy bridge right away..for dozer, we'll have to wait and see..maybe less for multithreaded apps where it should thrive well.
Old August 24, 2011, 08:08 AM
Cptn Vortex's Avatar
You'd be amazed how good even a single 320 Rad can be. Add a 220 in there too and you have more than enough. I am running, all in 1 loop, 2 x 120W Clovertown Quadcore Xeons and my GTX 580 OC'd to 950Core. This is with 1 little compact pump, and somewhat restrictive EK Supreme's with 2slot plates. I'm getting a 10c temp diff between idle/load, not too shabby.
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
[WTB] Corsair 700 / 800D severity Buy/Sell & Trade 4 April 12, 2011 10:54 AM
Gallery Watercooled 800D Slaughter Case Mods, Worklog & Gallery 7 February 24, 2011 01:22 PM
Completed SR-2 in 800D stoanee Case Mods, Worklog & Gallery 12 February 3, 2011 09:56 AM
800D Madmike2010 Cases 4 September 21, 2010 08:17 AM
PC: 800D BobbyLou Off Topic 3 March 4, 2010 06:41 PM
