IMO either build a new rig from scratch (2500k, 560ti/hd6950 based), or if money is tight go for just a power supply and video card (that way they can be transferred to a new build down the road). I wouldn't put any money into ram etc that couldn't go in a new rig. You didn't give a budget, so I would say best bang for buck is any quality power supply 600+ watts and a gtx 560ti or hd 6950 (these will likely be bottlenecked by the CPU). Can recommend some PSU if you don't know which are good, or can amend the recommended parts if budget doesn't allow them or if he is after a smaller upgrade to make the game playable vice maxed graphics.
EDIT: A decent upgrade for graphics that would be more $ friendly would be hd 5770/6770/6850/ or gtx 460 768mb/1gb (better to not get an SE model). and any quality >500w PSU.
I don't know how demanding BF3 is, so these are just my opinions on money well spent.
__________________ Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
