Old August 14, 2011, 02:11 PM
Default the tashash build
hey guys, i wanna know what ya'll think about my new rig
amd phenom ii x6 1100t processor
amd radeon 6950 2gig HD, crossfire graphic cards
Asus Sabertooth 990fx mother board
1T harddrive
1200W powersupply
12 GB's ram
Windows 7 64bit.
Old August 14, 2011, 02:18 PM
supaflyx3's Avatar
Looks fine to me, pictures? although the PSU is overkill
Old August 14, 2011, 02:22 PM
thanks, i do not have any pictures yet, its in a NZXT Phantom case, im bummed it only came with 4 fans and not the 7 it says it has, but i found the fans on newegg for cheap! should be good airflow.
Old August 14, 2011, 03:25 PM
southbay's Avatar
Power supply is a major overkill, I'd say 1000 needed.
The GPU's will be around 280w even though they require 500w min.
Edit: I'm also going to get this case. It only says 4 for me, with the availability to expand to 7.
Old August 14, 2011, 03:31 PM
everyone says 1200W is overkill but its not gonna hurt the system right? im just playing it safe lol
Old August 14, 2011, 03:32 PM
southbay's Avatar
That's a valid point. Always helps if you want to hit the hard stuff ;)
Old August 14, 2011, 03:35 PM
haha yeah i'm pumped for this rig, some people tell me to get a SSD drive but im debating it. and what games should i get, im lookin at Crysis 2 and Witcher 2.
Old August 14, 2011, 03:42 PM
supaflyx3's Avatar
Get an SSD, you won't regret it.
To build, or not to build: that is the question Timid newbe New Builds 5 August 12, 2010 04:33 AM
New Build- Corsair 800D --> My cleanest build ever. Watercooled btdvox Case Mods, Worklog & Gallery 28 May 11, 2010 01:07 PM
Windows 7 Build 7000 VS Windows XP SP3 Build 2600 Benchmarks Veritas Overclocking, Tweaking and Benchmarking 3 March 3, 2009 02:48 PM
