Old July 21, 2011, 02:31 PM
Default Need opinion on first build before I order..
So I decided to take (Dangtx) advice and order a new system instead of dumping money into my q6600 build. This is my first full build and was wondering what you guys thought. I am saving for my winter vacation so I have allowed myself a $1000 budget. I mostly play mmos, and the odd shooter. Really want this for upcoming Tera and GW2 .
Specs:
Processor: Intel i5 2500K 3.30GHz w/ 6MB Cache
Mobo: Asus P8P67-M Rev 3.0
Mem: Kingston HyperX Genesis 4gb 1600mhz ddr3
HD: Western Digital 1TB Caviar Black 7200rpm w/ 64mb
GPU: Asus ENGTX 460 1GB
500w psu
OS: Windows 7 x64
Optical: LG DVD/BR RW
Any help would be great, I have never done this before so I am not sure if I am missing anything or putting things together that will run good together.
Thanks!
Old July 21, 2011, 03:49 PM
PerryC's Avatar
The only issue I have with this build is the psu. I can't figure out who the OEM for their power supplies are. This is definitely one place you do not want to go budget on. You might want to consider a 500w unit from Seasonic or Corsair.
Old July 21, 2011, 04:10 PM
Changed the case and psu already ha.
Old July 21, 2011, 04:22 PM
what perryC said, otherwise maybe look at newer gen GPU unless you are getting a rly good deal for a 460 (see under 130$ if SE or about 140-150$ for original 1GB cards).
I'd suggest going to NCIX on a week they offer free/cheap shipping and just pricematch everything you can (if you already know the drill good/otherwise ask).
good luck with the build and hope to see you in GW2!
Old July 21, 2011, 04:46 PM
Already got the 460 for free..jusst want to order everythiing else. I changed case to thermaltake v3. Black ed. And haven't decided on the exact psu just. Wanted to know if 500 is good enough. System so far is around 800.
Old July 21, 2011, 05:14 PM
get the gskills kit on sale @ ncix for 29$
personally i'd go for @ least a 1866 kit
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old July 21, 2011, 05:16 PM
500 Watts is good enough, just don't cheap out too much on the PSU.
Old July 21, 2011, 05:20 PM
Thanks for the help..can you link a good psu for me?
Old July 21, 2011, 05:25 PM
uhm offhand, a decent model is NCIX.com - Buy Corsair Builder Series CMPSU-500CXV2 500W ATX Power Supply Active PFC 120MM Fan *3 Year Wrty* - Corsair - CMPSU-500CXV2 - in Canada
Old July 21, 2011, 05:49 PM
PerryC's Avatar
The one Larkstarr linked will work fine, unless you decide to add a second video card then you will want to get as more powerful one. If that is something you are never going to do then that Corsair 500w will provide more than enough juice for you.
Final opinion before I order kanadien New Builds 34 August 17, 2010 02:20 AM
Opinion for New PC Build Up Shaggyk0 New Builds 12 August 7, 2010 04:35 PM
Need your opinion on a first build veedub6 HTPC Systems & Software 14 June 25, 2010 04:08 PM
Opinion needed on my i7 build ali7up New Builds 4 January 17, 2010 10:30 AM
New Build- need advice, opinion Etc UberMoo Off Topic 1 December 17, 2007 10:20 AM
