Old July 9, 2011, 05:50 PM
Trial Member
Default $720 build
hi all
i need help picking part,i'll be buying from newegg,thx
1.What YOUR PC will be used for gaming only
2. What YOUR budget is. $720
3. What country YOU will be buying YOUR parts from. USA
4. IF YOU have a brand preference.intel
5. If YOU intend on using any of YOUR current parts.No
6. IF YOU have searched and/or read similar threads. yes
7. IF YOU plan on overclocking,No
8. WHEN do you plan to build it?today
9. What resolution do you u,1600x900
Old July 10, 2011, 07:13 AM
Reyzac's Avatar
Have a look at the August issue of Maximum PC where they detail their process of a $667 PC and modify it to fit your budget. Maybe upgrade the CPU, or the GPU. (It would be nice to bump up to a 6850).
Who needs a real doctor when you got my machines and their scary needles?
I also go by Silver Blues in lots of other places.
Old July 10, 2011, 08:06 AM
PerryC's Avatar
You can find that article online here: Maximum PC | How to Build a Kick-Ass Gaming Rig for Under $700
edit...I would definitely consider a better psu than the one they used in that build.
Old July 10, 2011, 09:10 AM
Reyzac's Avatar
Agreed. Always get as good a PSU as humanly possible. Look for a deal.
Old July 10, 2011, 11:34 AM
My general rule of thumb is that the PSU has to be at least 10% of the cost of the entire build. Corsair has good budget PSU too. (CX builder series)
Old July 10, 2011, 07:24 PM
I generally shy away from "this has to cost fraction X of entire setup Y" because it sometimes can lead you astray. My favourite is the Future Shop people trying to convince you the HDMI cable has to cost 10% percent of the price of the TV or whatever it was.
Anyway I agree that the PSU should be changed for that build.
At the same price, the older Antec Earthwatts 380W power supply will be better - an i3 plus a GPU with only 1 supplemental power connector would have a hard time consuming over 230W (~70W CPU, 150W max on GPU, and Intel's new chipsets draw insignificant power):
Newegg.ca - Antec EarthWatts Green EA-380D Green 380W Continuous power ATX12V v2.3 / EPS12V 80 PLUS BRONZE Certified Active PFC Power Supply
It seems the Gigabyte motherboard in the MaxPC was also pricier on Newegg so here's some alternatives:
Newegg.ca - ASUS P8H67-M LX (REV 3.0) LGA 1155 Intel H67 SATA 6Gb/s Micro ATX Intel Motherboard
Newegg.ca - MSI H67MA-E35 (B3) LGA 1155 Intel H67 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
If you count on MIRs you should be able to find a Radeon 6850 for ~170 - 20 MIR or something to bring it virtually to the $150 that they depicted for the lower end 6790.
I think that case is horrible to look at - a Cooler Master Elite series at the approx. same price will net you better cooling.
Aside from that, it looks like the build on Reyzac / PerryC's reference is solid.
overclocking my phenom II x3 720 ultraman7k Overclocking, Tweaking and Benchmarking 16 April 19, 2010 12:05 AM
Want to bump up my 720 Farmrush Overclocking, Tweaking and Benchmarking 9 September 21, 2009 11:51 AM
X3 720 BE + DDR2-1066 Evylldemon Troubleshooting 15 July 26, 2009 12:17 PM
Phenom II X3 720 Jim CPU's and Motherboards 33 March 29, 2009 10:21 PM
what do u think? AMD 720 BE bangers'n'mash New Builds 6 March 19, 2009 11:56 AM
