Old June 21, 2011, 03:30 PM
Default First build....$1500 budget
Hello!
This is my first complete build. I've changed graphics cards, RAM, etc. but never actually built a whole computer myself. I was going to go with cyberpower until I saw your HardwareCanuck videos which gave me some confidence to finally build one myself! :)
Any comments or suggestions would be awesome! Thanks!
Approximate Purchase Date: Next week or two
Budget Range: $1200-$1500
System Usage: Gaming
Parts Not Required: I need everything except the mouse since I am moving from a laptop to a desktop. So a keyboard and monitor need to be included in the budget.
Preferred Website(s) for Parts: Newegg
Country of Origin: United States
Parts Preferences: Intel & Nvidia
Overclocking: Maybe in the future when I learn how to do it but not initially
SLI or Crossfire: Maybe SLI in the future to keep up with games
Monitor Resolution: The monitor I am looking at is 1920x1080
Additional Comments: It needs to light up like a Christmas tree
Parts:
Case: Antec Nine Hundred Two V3 Black Steel ATX Mid Tower Gaming Case
http://www.newegg.com/Product/Prod [...] 6811129097
I love the look of the hundred series but I'm not sure which one to get exactly.
CPU Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
http://www.newegg.com/Product/Prod [...] 6819115072
MOBO ASRock P67 EXTREME4 (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Prod [...] 6813157229
RAM G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
http://www.newegg.com/Product/Prod [...] 6820231314
VGA EVGA SuperClocked 012-P3-1573-AR GeForce GTX 570 HD w/Display-Port (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Prod [...] 6814130622
PSU ENERMAX NAXN 82+ ENM750AWT 750W ATX12V v2.3 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Prod [...] 6817194086
DVD Sony Black 18X DVD-ROM 48X CD-ROM SATA DVD-ROM Drive Model DDU1681S-0B - OEM
http://www.newegg.com/Product/Prod [...] 6827118031
HD SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Hard Drive -Bare Drive
http://www.newegg.com/Product/Prod [...] 6822152185
Monitor Asus VW246H Glossy Black 24" 2ms(GTG) HDMI Widescreen LCD Monitor 300 cd/m2 ASCR 20000:1 (1000:1) Built-in Speakers
http://www.newegg.com/Product/Prod [...] 6824236049
OS Microsoft Windows 7 Home Premium SP1 64-bit - OEM
http://www.newegg.com/Product/Prod [...] 6832116986
Keyboard
Saitek Eclipse II Illuminated Keyboard
http://www.newegg.com/Product/Prod [...] 6823175001
Total: $1,493.56 shipped
Also, are there any big hardware releases coming up soon that I should wait for? Or is now as good as any time to build a new rig, I'm hoping it will hold up pretty well for at least 3 years.
Any help would be great, thanks!
Old June 21, 2011, 04:01 PM
3.0charlie's Avatar
Nice build, the F3s are great drives. To complete I'd add a HSF, even though you won't be oc'ing from the getgo. It'll keep your cpu nice and cool.
Newegg.com - CORSAIR CAFA50 120mm CPU Cooler
Old June 21, 2011, 04:17 PM
look in the haf series for cases :)
the 912 kicks bott
seasonic for psu,not that the enermax you chose isnt very good :)
and welcome aboard
Old June 21, 2011, 04:33 PM
3.0charlie's Avatar
Cases are a personal choice.
PSU is just fine, if you compare the 'egg pricing. And it's modular.
Old June 21, 2011, 05:54 PM
Thanks for the fast responses! Those coolermasters look cool but I still really like how the Antec looks :)
I was recommended this PSU, would this work alright? It's an extra 100 watts and is $99 after rebates. I haven't ever heard of Raidmax though...are they reliable and built well?
Newegg.com - RAIDMAX RX-850AE 850W ATX12V v2.3 / EPS12V SLI Certified CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply
What is the install like on the custom cpu cooler? I see in the antec case specs that it has a cpu cutout
Old June 21, 2011, 06:11 PM
3.0charlie's Avatar
It's an Andyson-based unit, but being Raidmax, I wouldn't touch it with a 10 foot pole... stick to Enermax, Corsair, Seasonic.
Typically HSFs are easy to install, I always set them up 1st on the board then install the whole kit in the case. I found it was easier like that.
Old June 21, 2011, 06:17 PM
PerryC's Avatar
The cpu cutout is just a hole cut in the case motherboard tray to make installing the cpu cooler easier. However like 3.0 said its way easier to install before putting the board in the case.
Old June 21, 2011, 07:01 PM
Thanks! I'll look into getting the cpu cooler then...
Here's a good corsair?
Newegg.com - CORSAIR Enthusiast Series TX850 V2 850W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power Supply
Old June 21, 2011, 07:05 PM
PerryC's Avatar
Both that Corsair and the Enermax you originally selected are decent PSU's. My personal preference would be the Corsair though.
on the new hardware front.. there will be some large releases later in the year.. but your looking at between 3 - 5 months..
Your shout whether to wait or build.. IMO wait and see what the new stuff is like..
Then you can either get the new bits if they kick ass or the stuff you have listed as they will drop in price but it's personal choice and a matter of how much / soon you need / want a new build.
Budget i7 3d/Comp workstation (sub $1500) therealmark New Builds 5 August 16, 2010 04:55 PM
$1500 i7 Build, need some help :P Bumchoda New Builds 18 May 27, 2009 06:49 PM
$1500 first build GhostOps New Builds 34 October 27, 2008 04:12 AM
New Build ($1500) miggs78 New Builds 8 August 6, 2008 12:09 AM
New Computer Build - $1500 Budget Kandorf CPU's and Motherboards 7 September 24, 2007 01:24 PM
