-   New Builds (https://www.hardwarecanucks.com/forum/new-builds/)
-   -   2000-2400 dollar gamingcomp (https://www.hardwarecanucks.com/forum/new-builds/44251-2000-2400-dollar-gamingcomp.html)
A_Dude June 18, 2011 11:05 AM
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
9. What resolution do you use?
1. Gaming ofc!
2. 2000-2400 USD's or in my currency 15 000 swedish crowns.
3. Sweden. Dustin, Inet and so on.
4. Dosent matter, as long as its the best.
5. None.
6. No.
7. Umm, probably, not sure.
8. November or December this year.
9. 1680 x 1050
Thanks in regards, cheers!
draemn June 18, 2011 11:49 AM
1) Buying a 20" monitor for a $2400 computer is weird at best (even 22")... you really should step up to 1920x1080 or 1920x1200 if you can find it.
2) Because EVERYTHING new is coming out in Q4 of this year and we don't actually know how it will perform (we just know it is coming out), there is no point building your parts list until closer to the date... say October?
_dangtx_ June 18, 2011 12:22 PM
right now a 2500k on a p67 or z68 would be the way to go.
the sabertooth and pro are nice from asus.
8 gigs of ram or more if you run 64 bit os.
for gpu,right now i'd go for one 580 or maybe a couple 6950's?
ssd of your choice for os, 2tb for storage..
case wise, whatever you like and isnt over 200 bucks.
seasonic or seasonic built for psu. 500 watts and up for single gpu.
Dzzope June 18, 2011 09:34 PM
9. 1680 x 1050
as the first reply said, wait till nearer the time. there will be new CPU's and GPU's available about then and everything will change (if not in performance at least in price)
And a rig of that quality is overkill on an monitor doing 1680.. Advise cutting your pc spec a bit for a monitor upgrade.. suggest a 24" with 1920 1200 res, beats 1080 IMO..
A_Dude June 28, 2011 01:48 AM
I dont know How The monitors works, My monitor is Default on 1680 x 1050, dunno if it can go higher.
Dzzope June 28, 2011 03:41 PM
Probably not (unless it's your pc that can't go higher..
Whats the model of the monitor your using?
BrutalGreen June 28, 2011 04:00 PM
invest some of that money in a new monitor(s)...it will provide a much more balanced and enjoyable experience! also too early to rly give advice now for a build in nov/dec...
A_Dude July 2, 2011 12:24 AM
Umm, i have a computer from 2001 (haha i know) so My graphics card is a Geforce 4200 ti with AGPX8, so My monitor is from like.. 2009
