you can even cut budget even more, get a Phenom II X2 black edition, the 555 I heard is amazing at unlocking cores, get a mobo with good history at unlocking cores, like Asus/MSI. 8GB might be overkill for gaming, you don't really need that much RAM unless you do a lot of virtualization, 4GB should do it for the beginning. You might also want to look for a better cooling solution than the stock fan, something in 30$ range should do the trick, I am thinking something like Scythe Shuriken/Big Shuriken. And when you don't game you could fold some. Hexacore would help you for real only if you would do video transcoding/production.
