Old June 14, 2011, 11:55 AM
Default First Gaming Build - Need A Bit of Help
Hello hardware canucks, I have decided I would like to build a PC for myself after buying from the bigger companies like Dell and HP for the past few years. It will be used for gaming and my budget is around 1000$ Before tax. I have put together what looks to be a good build, but some suggestions would be greatly appreciated. I plan to buy all my parts from NCIX, and have price matched the below build to $965.
~BK
Old June 14, 2011, 11:59 AM
Will take an Western Digital instead, but it's me , the rest look nice , take note ; the board you choose support Xfire but not SLI, not a problem with your 6950
Old June 14, 2011, 12:21 PM
Alright mate, Is there any real difference between the WD green and the WD black?
Old June 14, 2011, 12:23 PM
you don't want a green for your OS, they are slow, aside black are waranty for 5 years and green 3
Old June 14, 2011, 12:24 PM
Alright, also, do you think the power supply is a bit overkill? Or is 750w just the right amount?
Old June 14, 2011, 12:30 PM
Your PSU is fine, if you OC it's always good to have power under the hood. Some may say to get a modular one to eliminate some wire in the case...
Old June 14, 2011, 12:32 PM
Yeah I plan on overclocking, also unlocking the 6950 to a 6970, if you can still do that.
Old June 14, 2011, 01:14 PM
Chalaska's Avatar
Chances are your new sapphire card will not be reference so there won't be a good chance unlocking it to the 6970. I agree with the WD recommendation also.
Old June 14, 2011, 03:14 PM
Iceman's Avatar
Looks good, although I'd grab some DDR3 - 1600 memory instead... such as the G.SKILL Ripjaws X F3-12800CL9D-8GBXL 8GB 2X4GB DDR3-1600 CL9-9-9-24 Memory
Antec P182 - Gigabyte EP35 DSR3 - E8400@3.6Ghz - 2x2 GB GSkill F2 6400CL4 - HIS HD 5770 - Audigy 2 - Corsair Force 3 60GB - 7200.11 500GB - Silencer 610W - Windows 7
Old June 14, 2011, 03:30 PM
looking good.
bit of an overkill psu wise but hey.
Xbox and PS3 Holding back Gaming ( Bit- Tech) ZZLEE Reviews & Articles from the Web 10 March 21, 2011 08:11 PM
Planning a new build? Need a x64 bit OS? I have a DVD copy of Win 7 to give away! Triggz New Builds 12 March 22, 2009 03:17 PM
Non gaming build- Bit of a read..... dmelchart New Builds 2 January 25, 2009 07:28 PM
64 bit Vista vs Gaming - what's the truth? dadzilla Gaming 17 October 8, 2008 12:19 PM
bit-tech's gaming mouse group test Supergrover Peripherals 2 December 9, 2006 12:27 PM
