Old June 5, 2011, 10:49 AM
Ebbtides's Avatar
Default Gf's quiet PC
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
9. What resolution do you use?
Well, I figured I should get come input on a build I'm nearly finished with - you guys seem to have a really great grasp on what works best. This is my third computer I've built myself, so I'm still fairly new to things, but have learned a lot on this particular build.
This is a PC for my girlfriend, who will most likely use it for gaming, photoshop, video editing/rendering, and light coding.
Coming into this build, I originally thought I'd scavenge a few parts from my PC till bulldozer came along. now that it's delayed, I've ordered most of the parts - with around a 1000 - 1200 $ price tag at the end, thanks to NCIX and Dazmode deals.
Canada exclusively.
Since this was to be partly scavenged from my current AMD system, anything AMD and ATI. As for the case, the entire quiet PC is mounted in a Fractal Define R3 case.
As mentioned, intended on using my MSI 890fx board, as well as my 1100t - but plans fell through with the bulldozer delay.
Browsed quite a few - I see I'm not the only one who's been delayed by the Bulldozer!
This is a good question - Ideally I would say yes, but silence and stability is the heart of this build. I want something low maintenance, sturdy, and versatile all while being whisper quiet for the mrs.
Most of it is already done - but I'd like to finish it as soon as possible.
I think she'd be using 1920 x 1080.
Onto the particular parts now. I scavenged most of these through NCIX and Daz over the past 2 months.
Case: Fractal Design Define R3 Black - A NCIX bundle with the Coolit ECO ALC cooler esentially free.
PSU: Corsair TX650V2 - wishing I went with something modular.
Mobo: Asus M4A89TD Pro - picked it up for really cheap with another Asus GPU (below) at NCIX.
GPU: Asus EAH6850 - non-reference HD6850 with a decent cooler on it.
CPU: AMD 1090t - I feel more comfortable with the Black chips like my 1100t, so I figured I should bite the bullet and grab a 1090t.
HDD: WD Caviar Black 1TB - she has several externals as well, so storage isn't a big issue.
CPU cooler: Coolit Eco ALC - came with the R3 case in a bundle, and was essentially free. I think I payed 5 dollars for it, so I figured I'd try it out. Low maintenance, and I heard it was a good performer.
RAM - Corsair Dominator 1600 8gb (4x2gb) DDR3
ODD: Samsung dvd writer - she won't be watching blu-rays.
OS: Windows 7 64 bit
Fans: Feser Triebwerk lowspeed 120-55cm radiator fan - really impressed by this thing, and I figured I'd try one out on her computer since it's a "quiet" build and all. I was hoping to mount this onto the Coolit Eco ALC, but the specialized screws aren't compatible unfortunately. I've still found a use for it however!
Old June 5, 2011, 12:03 PM
get a 2500 non k on an h67 mobo?
hr-02 for fanless operation. not that the stock intel is loud or anything
thats a ncie quiet psu. or a seasonic fanless? :)
case wise thats nice.
Old June 5, 2011, 03:23 PM
WD Blacks are not quiet. Strongly suggest purchasing a 60GB SSD in its place.
heatware
Old June 5, 2011, 04:13 PM
NI3 NI3 is offline
I really don't see the point of using an ECO ALC with a non k processor, If you do decide to go non-k, pick up a quieter air cooler.
Pick up an SSD, or a caviar blue at least, because, as mentioned above, the blacks aren't really quiet.
Define R3 - How quiet is it? ADay2Long Cases 5 April 30, 2011 07:34 PM
Quiet microphone JMCD Troubleshooting 10 January 30, 2011 01:45 AM
Quiet folding jibz HardwareCanucks F@H Team 11 January 4, 2011 09:19 PM
A quiet keyboard Prolab Peripherals 12 November 25, 2010 12:20 PM
Looking for QUIET 120mm fans Caldezar Air Cooling 20 July 20, 2010 01:32 PM
