Old June 4, 2011, 01:35 PM
NI3 NI3 is offline
Digital Visual Interface - Wikipedia, the free encyclopedia
Old June 4, 2011, 01:37 PM
Reyzac's Avatar
Nice, looks like they're both Dual-Link DVI-I. Thanks NI3.
Who needs a real doctor when you got my machines and their scary needles?
Old June 5, 2011, 05:40 AM
As someone who also builds on carpet, I agree that a wrist strap is fine as well. I built my Sandy Bridge during the winter when it was dry in the house, and I just made sure that parts were connected to something that is grounded or out of the anti-static bag only when I was ready to use them. I like PSUs that have an on-off switch (most of the non-exploding ones do) because you can use them as ground by having them plugged in but turned off.
It may be a paranoia step, but while I was installing the CPU and cooler to the motherboard, I also had the motherboard connected to ground. I did that by running an test lead (wire with alligator clips) between a USB cable connected to the motherboard to a computer PSU (actually an old AT, no 'X' power supply ) that was off.
Old June 5, 2011, 06:28 AM
Reyzac's Avatar
Interesting idea but maybe a tad overkill. I suppose I'll be fine with a strap and touching the case.
Old June 5, 2011, 10:42 AM
Ebbtides's Avatar
If you're super concerned about ESD - you might think of investing in an entire work kit. I found on of these in my dad's office in a back closet, and have liberated it for a greater good. They run anywhere from 60-80 bucks though.
3M 8501 Static Dissipative Field Service Kit, Standard, 0.021 on sale at Global Test Supply
For something hiding in a back office though, I gotta say this has served me extremely well. Great piece of mind.
Old June 5, 2011, 03:13 PM
Reyzac's Avatar
Wow.
Not that concerned, like I said just trying not to fry my new rig.
Static IP's from ISP and Wireless Setup - Help GameOnTurtle Networking 14 September 4, 2010 09:41 AM
did i just my 8800gt with static? kuziwk Video Cards 10 February 3, 2010 11:50 AM
Setting Static IP in Vista 64 not being saved vintank Networking 4 July 15, 2008 11:37 AM
Anti Static Devices? tgraszat14 Troubleshooting 18 February 6, 2008 06:14 PM
Static In My Sound? kcksteve Audio 7 August 31, 2007 10:49 AM
