<~----> First Intel in 15 years, Sandy Build - Page 6 - Hardware Canucks
  #51 (permalink)
Old June 25, 2011, 07:55 PM
Supergrover's Avatar
I am doing it right Dan, it cycles and reboots as it is suppose to and ends with the solid mem led lit, memory error. No biggie have a few sets in my cart just doing some surfing and will order of them up, have to place a another order anyways
R.I.P.
  #52 (permalink)
Old June 25, 2011, 08:08 PM
ok
on some i got it by just touching the button,others i hold it past the blinking as per the asus instructions
only then i got it going
YouTube - &#x202a;ASUS MemOK!&#x202c;&rlm;
tht guy holds it just enough.
give it a touch first. no go?
then hold it like you wont let it go..30-60 secs.
worked for me at least so far :D
edit : the only way it works as per the manual is if the light(red) is lit and you hold it right then and there. it will have the same effect(shut down,reboot) even if the light is not lit.
  #53 (permalink)
Old June 25, 2011, 09:52 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
I've had great results with MemOK.
  #54 (permalink)
Old June 25, 2011, 10:00 PM
I have tried holding the button for different degrees of time, holding it longer than 10 sec just cause it to reboot and do its thing. I tried holding it 45 seconds same thing.
I can tell the mem ok is doing its thing but it just loops then goes to a solid steady light and from what I am reading that is a memory error.
R.I.P.
  #55 (permalink)
Old June 26, 2011, 09:27 AM
SKYMTL's Avatar
Yup, sounds like the memory or memory controller on the CPU is DOA.
  #56 (permalink)
Old June 26, 2011, 09:39 AM
My thoughts exactly Mike, ordered some corsair vengeance 1600 since it makes the qvl. First time in 3 generations of ram ( ddr, ddr2, ddr3) that I have had a compatibility issue with Mushkin.
R.I.P.
  #57 (permalink)
Old June 26, 2011, 10:23 AM
ok,so does it work fine in another machine? if so its just the board that is picky.
before id try samsung for compatibility,these days mushkin to be sure.
not the fancy stuff though. regular kits,those will work left and right,especially the
1.5v and below ones :)
  #58 (permalink)
Old June 29, 2011, 12:43 PM
Wow frustration factor 5, Memory arrived yesterday installed it last night , would post then not post on reboot, pulled the board, striped everything down to basics. 1 ram, cpu and low powered gfx (4550) booted repeatedly, added in 1 more stick, booted fine. Switch out the 4550 for the 6970 bam sporadic boot. Switched in a 275 same thing, switched in a 4890 same thing. Switch out the board ( I have another sabertooth kicking around here ) everything boots perfectly. So in the end bad board, just going to reinstall into the case.
R.I.P.
  #59 (permalink)
Old June 29, 2011, 01:02 PM
3.0charlie's Avatar
Been there, done that. Shite does happen. Taking a breather, and a good 15y scotch usually helps to make it through.... =)
Enjoy your new rig Kev. And now oc the darn thing until it screams.
  #60 (permalink)
Old June 29, 2011, 01:15 PM
i got an easy fix for you..get a giga board :D
1st build in years.. and New! The Chemist New Builds 7 December 27, 2010 05:47 PM
New Build after 2 years Cobrajr122 New Builds 11 September 12, 2010 09:12 AM
7 years later... ready for another build. Peanutmc New Builds 17 August 30, 2010 02:07 PM
New Build (First in years) Taichan New Builds 0 June 13, 2010 02:13 AM
About to build first PC in 8 years...how's this? computermonkey New Builds 20 October 16, 2008 04:45 PM
