Originally Posted by fishingfanatic Another suggestion is 2 look at a modular psu. It makes cable management much easier and doesn't restrict air flow with unused wires. |
mostly true but that would be extra costs, and ive already managed to fit all the unused cables neatly behind the motherboard on a 912 from a mushkin joules 1000w! a TX750 is easy stuff in comparison...
but yeah for an extra 10$ the extra megaflow fan is quite welcome (the 912 doesn't have stellar cooling stock but it does come with the options to make it truly amazing by adding fans).
One problem tho, its a massive dust magnet...maybe look into cases with included dust filters. Also you could check out the Zalman Z9 Plus which has better stock cooling than the 912 for about the same price and IMO less ugly looks! only thing that turns me off on that case is the breakoff expansion slots, if you can live with that at 55$ its a bargain (just buy 2 dust filters and slap them on the side and mount the top fan on the side too and u get basically 90-100$ case performance for half the price).
