Old May 22, 2011, 05:48 PM
Default Need input and Advice!
okay so i have about 450$ to spend and i just need some advice on if im getting the most out of 450$ and if you have any suggestions tell me but try to keep it under 450.
the mother board:
BIOSTAR TA880GB+ AM3 AMD 880G HDMI Micro ATX AMD Motherboard
the CPU:AMD Phenom II X4 925 Deneb 2.8GHz Socket AM3 95W Quad-Core Processor
RAM:G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
CD/DVD-rw drive:
LG Black Blu-ray Drive SATA Model UH12LS28
The Hard Drive:
Seagate SV35.5 ST3500410SV 500GB 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
Case:
Thermaltake V6 BlacX Edition Gaming Chassis Mid Tower Steel Computer Case BlacX Top Mounted HDD Docking Station
Power supply:
Thermaltake TR2 W0070RUC 430W ATX12V V2.2 Intel Core i7
this is also my first build so i'm not looking to spend a lot yet till i get this one working and also if you could tell me if this could run any games or anything
oh and this cost me about 430 so far
Old May 22, 2011, 09:59 PM
You will get better performance out of an i3 2100/h67 combo. with the money you save you can also pick up something like an HD 5770 which will give your system a huge boost.
Also that HDD kinda sucks better off with a WD caviar black 32mb cache, it'll be much faster and more reliable.
I also recommend a seasonic PSU better made for about the same price.
Old May 22, 2011, 10:51 PM
save your money till you can get a better pc
Old May 23, 2011, 01:29 AM
well i would not buy an i3
theres a few games out there now that benefit from 3+ cpu cores
whats your spending budget ?
do you already have a video card ?
Old May 23, 2011, 07:05 AM
NI3 NI3 is offline
Are you in Canada, I am wondering because you listed .com, not .ca. If you are in the states there are good deals from microcenter on AMD CPUs. Micro Center AMD Processor Bundle Savings
Also, why not get an x2, and unlock it. If you want to stay with a quad core, there is an MSI 880G/x4 965 BE for $5 less, and a better cpu.
edit: Do you require a graphics card? how will the pc be used?
Old May 23, 2011, 08:35 AM
fishingfanatic's Avatar
Smile New Build
I agree with the others. Save your money 4 something later on or if ur intent on using those funds b4 they
get frittered away, consider getting a top end gpu 4 now and work on building your next system to really
get the most out of your gpu.
Don't know much about Biostar. If they've been good 2 u, then stick with em. I've had great results with
Asus and DFI boards.
Another who thinks switching your psu 4 another brand would b wise.
HDD wise, Samsung F3 or WD Black r great with the sata3. Fast 4 a spindle drive.
Is there a reason why ur going 4 a Blu-ray? Perhaps put it off 4 now and consider this a system add on
later.
There r some great new cpus coming down the pipe, so that's why I'd wait a bit. A great gpu makes a huge
difference that will go with an upgrade later on as well.
If u go that route, make certain your psu is sufficiently powerful enough. Use the powerr calculator 2 check
your needs.
Good luck with the new component(s) and welcome 2 HWC!
Old May 23, 2011, 07:34 PM
well is the i3 the same price or something and i plan on doing like low games nothing to big but yahh i agree ill put the blu ray on the later list.
im not in canada either so yeah
is DFI and Asus boards better ? cause im thinking about getting one
any other Psu's that you guys would suggest?
i have about 500 to 600 to spend, should i get a video card cause the one i had has one on the motherboard
Old May 23, 2011, 07:39 PM
dfi only makes boards for the industry..so no go there.
asus,giga,biostar,asrock,all the way :)
Old May 23, 2011, 07:48 PM
well i decided to go with asus board and a phenom ll
for about 239$ so tell me if thatd be a good board maybe?
AMD Phenom II X6 1055T Thuban 2.8GHz Socket AM3 125W Six-Core Desktop Processor
and also would this be a good drive for the price? ASUS Black 18X DVD-ROM 48X CD-ROM SATA DVD-ROM Drive Model DVD-E818A7T/BLK/B/GEN
Old May 23, 2011, 08:10 PM
NI3 NI3 is offline
There is the same bundle for $220 at microcenter. If you dont live near one, if you know someone near one, you should ask them to pick one up and mail it. Even shipping would be about $10 via usps flat rate, so you save there.
Need input :) Cornholio New Builds 6 May 22, 2011 07:15 AM
Looking for some input dragoonxx Storage 0 November 22, 2010 12:43 AM
HTCP "Boom box" advice , thoughts , input? ParkerPWNT HTPC Systems & Software 0 June 3, 2010 04:11 PM
i7 input doggggboy New Builds 50 February 12, 2010 10:44 AM
Mutiple Audio Input Device Advice audio_newbie Audio 5 May 17, 2009 09:01 AM
