Originally Posted by super_coo Also I'm in Canada so can't shop at the .com Newegg. |
THat's the he linked you newegg.ca :S It very rare someone on a canadian forums tells someone to buy from a US website
Personally i would just go with the MSI. All the budget boards are pretty much the same, come with very little features(if thats what you want) and do the exact same job. If the price difference is $5, would be worth going with a more recognized brand.
Originally Posted by Borg I'm thinking going this route, too, with similar/same budget. No higher than $300, probably.
I was thinking of memory. Most of these boards have just the two slots. If I went with 8GB, the boards are limited to the speed compatibility and O.C., right?
Second question, how come most are 4-pin connectors instead of 8. Does that make any difference?
I hope these questions are ok, super_coo. Are they of any interest to you? |
Most of the budget boards(H67 in particular) do not overclock. You don't need very fast memory at all. I would pick the cheapest stuff you can find. Honestly you shouldn't even need 8gb. 4GB would be more than enough if you are going budget.
The only difference between 4 to 8 pin is power requirements. If you have a lower power requirement you don't need an 8pin connector.
