Okay, its time to spoil myself a little bit and build myself new pc. My current Dell E520 with a 1.86 Ghz dual core E6300 just isn't cutting the mustard anymore. Still works well for what I want out of it, just time for something better.
The biggest issue I have at the moment is the budget. I walked off the plane from yet another deployment to my wife's boyfriend handing me divorce papers, and the keys to the house, and then telling me that the kids would be at the house the next day.
Five deployments since 2003, I guess it was bound to happen sooner or later. Spent the last three or four months trying to sort out the crap sandwich I got force fed.
To keep myself from doing something stupid I have been doing alot of research on pc parts and upgrade routes.
1. I only really use my pc for light gaming, office type applications, emails and some websurfing. Gaming wise I don't play fps type games very often, nor do I play MMORPGs. Neverwinter Nights 2 and Mount & Blade:Warband, Warhammer 40K: Dawn of War I and II are the games I play most often. I have little to no interest in playing online.
2. Just looking for the best bang for the buck, but can't really afford to go to crazy with this build.
3. I will buying everything in Canada.
4. I don't have a brand preference...again I am all about the best bang for the buck.
5. I have a HAF 912 to put the new build into. Doing things bass ackword
...purchased 8 gb (4 x 2gb) of g. skill DDR3 1600 ram (F3-12800CL9D-4GBXL) through the BST forum here on HWC last night. I have a cd drive, dvd/cd burner (both sata) and a 250 gb WD sata hard drive I can use from my current pc, if I don't get new ones. As well, I have a Radeon X1600 512mb video card I can slap in the new build until I get a new decent one.
6. I have done a lot of research on the topic, looking at various cpu routes and the associated parts. By "a lot" I mean tons...comparing parts, reading reviews- both editorial and customer, and working up various builds to compare against each other.
7. Overclocking is something I would like to dabble in down the road, but if the parts I get don't allow for it then I am not going to lose sleep over it.
8. I will put it all together once I have all the parts, though that is going to take me a couple of months.
9. I have an Acer AL2216W monitor that maxes @ 1600 x 1050 resolution. It has both VGA and DVI-D inputs.
This all started with me looking to see what I could do to my Dell to get another couple of years out of it. I was looking at cpu, vid card and psu upgrades. Then I realized that the mobo I have can't support the cpus I was looking at...it only takes 65nm cpus. They are mighty hard to find new now. Since then I have been flopping between builds trying to use as much as I could out of the parts in my build. Somewhere in there I bought the HAF 912 case. Then after I started looking around the for sale threads here at HWC I threw a wrench into my own plans. I bought the DDR3 ram, which through out all the builds I had looked at previously.
I have decided to go with this beast to power the new build: Corsair HX650 modular
Newegg.ca - CORSAIR HX Series CMPSU-650HX 650W ATX12V v2.2 / EPS12V 2.91 SLI Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply
There isn't going to be much in my case...but I want it as clean as I possibly get it. It also gives me room to expand in the future.
Looking at the G Skill website and researching the motherboards certified to support the memory I bought, then I am looking at the P67 chipset. This combo allows me to dabble in the overclocking....
NCIX Bundle...Core i5-2500K and Asus P8P67 B3 mobo
NCIX.com - Buy NCIX Bundle Deal - Intel Core i5 2500K Quad Core Processor & ASUS P8P67 B3 Motherboard - Bundle Deals - 2500K-P8P67 - in Canada
I know I can forgo OC'ing this build by getting a i3-2100 instead.
Read user reviews of my memory I found that people are using it with other boards, it usually just ends up defaulting to 1333 mhz. More than one person is using the same memory on this set up:
Asus M4A79XTD Evo and Phenom II x 4 955 BE
Buy the Asus M4A79XTD EVO AMD 790X Socket AM3 Mothe Bundle at TigerDirect.ca
Not even looking at prices, rebates or anything like that at this time. By the time I can get these parts, any deals or rebates won't be in effect. Hell, who knows I might even see something else in the BST forum that I want. Time to go check that forum out now
Haven't thought about the video card too much either...don't need anything outrageous, it would be wasted on me.
Whichever way I choose in the end, it will be way better than what I am using.
